1 members (baldeagle), 68 guests, and 1 robot.
Topics128,037
Posts1,055,467
Members48,424
#1180989 09/03/2016 4:11 PM
Have 42, 1.5 ton.. Experiencing a grind from neutral to low or 2nd gear.. Also have the same from neutral to reverse. If i hold the clutch in for about 15-20 seconds the grind is still kind of present, but less noticeable.. I can not recall if it always did this or if its normal. Double clutching from 2-3, and 3-4 works well without grinding. Thoughts ?
I have a 4 speed in my 42 1/2 ton and it does the same thing. It has done that for 15+ years without issue. I assumed it is because shafts are still spinning after you push the clutch in.
When coming to a stop, I have learned to drop the tranny into second (my usual starting gear) when I drop below 5 mph. The tranny and engine at idle are synchronized at that speed and then you don't get the gear clash.
Kent
1937 Chevy 1/2 ton
1942 Chevy 1/2 ton
1947 Diamond T Model 509
1951 Chevy 1/2 ton
2 Offline
Mine will do the same thing, especially when everything is up to operating temp and the oil is thinner in the transmission. It doesn't take much drag through from the moving parts to make the disengaged clutch disk want to follow along with the movement when everything is turning free, and with no synchronizers there are only gear teeth to bump along until you pull it into mesh. However, with that said, mine will generally stay mostly stopped if you stop by holding the clutch and leaving the transmission in gear while stopping and then find neutral without lifting the clutch. Once stopped, you can shift to another gear generally without any clashing, except on occasion the high points on the teeth are lined up and you'll have to bump the clutch out slightly or just wait a moment for the teeth to creep past so they will mesh. I'm spoiled with the aux transmission, as I can pop it into neutral, and since there is nothing then connected to the output of the main transmission, it will slip into gear without any major clashing pretty quickly, and then the little bit of extra drag from the intermediate shaft and gears in the aux transmission spinning will slow everything down to a stop much quicker while keeping the clutch depressed. Although if your not patient, you can still get the aux into gear too soon with a satisfying clunk and a small hop forward in the truck....
The key is patience, sometimes a lot of it. The problem described is why many large trucks have a clutch brake that activates when the clutch pedal is fully depressed.
1946 Chevy Pictures
1946 Chevrolet 2-ton. In family since new. Splash oiled 235, 4 speed main, 3 speed aux, single speed 6.17 rear. Original GM supplied 12' stake bed, paint on sideboards is still from the factory.
Ride Along Video!
Ride Along with a little load
Video Channel
Crusing in the Passing Lane
Also, make sure the clutch is fully releasing.
Ed
