7 members (3B, Phak1, 1955 1 Series, Gib70, Joe H, KEVINSKI, 1 invisible),
133
Mod | | | Forums66 Topics128,092 Posts1,056,451 Members48,443 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2013 Posts: 17 'Bolter | | 'Bolter Joined: Dec 2013 Posts: 17 | I have a '53 GMC 1/2 ton with its stock Muncie 4-speed. Bought a 10" clutch kit thinking it would fit--does not. The pressure plate assembly is too deep. I'd like to keep the bigger clutch since the engine is a 302 with about 175hp. A shallower throwout bearing might cure the fit issue. A later bell housing if available may do the trick--need help/advise. Thanks
phone: 636-219-7705
