10 members (Gray_Ghost, RoadsScholar, 55shaker, Ponchogl, fonz8261, Guitplayer, Cletus1950, Otto Skorzeny, carbking, Greg_H),
99
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,131 Posts1,056,721 Members48,454 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2005 Posts: 227 'Bolter | | 'Bolter Joined: May 2005 Posts: 227 | Hi everyone... My c30 1-ton has stock 19.5" single rims. I have 2 rims that sets the tire further out inside the fender and 2 rims that set the tire further in inside the fender. I was told 1 set came from a Chevy and the other set came from a GMC. Does anyone know this to be true and if so, which inset (set-back) is Chevy or GMC? Here is a shot of the truck: http://s761.photobucket.com/user/cl...0Truck/IMG_3333.jpg.html?sort=6&o=13Any information would be greatly appreciated... Thanks.. Russ
1960 Chevy Apache (C10) 1965 Chevy C30 Dump Truck 1966 Chevy C30 Tow Truck | | | | | Joined: May 2005 Posts: 227 'Bolter | | 'Bolter Joined: May 2005 Posts: 227 | Bringing this back to the top... Any one have any info on this?
1960 Chevy Apache (C10) 1965 Chevy C30 Dump Truck 1966 Chevy C30 Tow Truck | | | | | Joined: May 2007 Posts: 1,718 Moderator: 60-66 Trucks; North Eastern Bolters | | Moderator: 60-66 Trucks; North Eastern Bolters Joined: May 2007 Posts: 1,718 | Maybe Grigg has an answer. Nice truck by the way. | | | | | Joined: Jul 2010 Posts: 592 Shop Shark | | Shop Shark Joined: Jul 2010 Posts: 592 | Russ, I was told...don't know if it is true or not...that the older version are the ones on the drivers side of your truck with the smaller hand holds and the smooth cones from the hand holds to where the edge of the hubcap meets the rim...and the newer version are the ones on your passenger side with the stepped cones and larger hand holds.
Both versions were made by Kelsey Hayes.
I have the stepped cone version on my '57 3600.
Once again hearsay, but I've been told the switch from old to new happened when Chevy changed from AD models to TF models midway through 1955.
Matt | | | | | Joined: May 2005 Posts: 227 'Bolter | | 'Bolter Joined: May 2005 Posts: 227 | Thanks HB and Matt...
Matt... I have noticed that old vehicles had the wheel further in thus more of the body hung over the wheels and later they moved the wheels further out for better handling, so your information makes sense.
