| | | Forums66 Topics128,035 Posts1,055,445 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2014 Posts: 49 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2014 Posts: 49 | 1954 Chevy Truck - 3100
I added 3 inch dropped leaf springs (front & rear) along with two inch drop blocks. The truck rides great but when I hit a dip the bumper stops are definitely hitting the frame. Has anyone trimmed these down so that aren't hitting so regularly? I'm not ever going to have really any heavy loads in it so not worried to much about metal hitting metal but do want some protection obviously.
Thanks for the time and help.
Scott M.
| | | | | Joined: Feb 2000 Posts: 5,195 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,195 | Tanking an inch off probably won't hurt or help much, and you sure don't want metal to metal contact. Try a longer shackle, it will raise it a little, but so much you notice. I put rear shackles on the front to raise mine after getting softer rate springs made. Just the 1" longer shackle helped over speed humps I have to cross. The ride hight didn't change much at all. | | | | | Joined: Dec 2014 Posts: 49 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2014 Posts: 49 |
Scott M.
