1 members (Danielbolt), 164 guests, and 3 robots.
Topics128,149
Posts1,056,818
Members48,456
#1180557 08/31/2016 2:44 AM
I have a 51 3100 that I am anxious to get going. I was planning on putting in an Okie bushing while I have the propeller shaft separated from the transmission. However there does not seem to be any available.
There does not appear to be any play in the shaft so I am wondering if I even need an Okie. Can anyone tell me how to determine if the bushing needs to be replaced. Thanks!
If you have no play, the bushing is most likely good.
If you have no leakage (front to rear, most likely), the seal is most likely good.
People usually install an Okie bushing (when available) when they have one of the above problems/symptoms.
Read HERE under.
Inspection
1. Check clearance between propeller shaft and its bushing.
Note: If this clearance exceeds .010" the bushing and oil seal should be replaced.
The thing is the propeller shaft may be worn too.
So replacing with the original bushing might not solve the clearance issue.
With the Oike bushing, the propeller shaft will ride on a different unworn spot.
Check out my Okie Bushing Photo Album
Also check out C h e v r o L E E, for Bushing Dimensions.
Vintage Auto Parts, Inc. might have Okie bushings in stock if you need one.
They call them Driveshaft Bushings and Seal Assemblies
jorb #1180585 08/31/2016 12:31 PM
Exactly the info I needed! Thanks guys!
