1 members (Jon G),
136
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,124 Posts1,056,334 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2006 Posts: 486 'Bolter | | 'Bolter Joined: Aug 2006 Posts: 486 | I'm putting a pertronix ignitor II ignition on a 292 I6. The Pertronix website says not to use solid core wires but they don't have a recommendation about plugs. I emailed them but got no response. Should I use the same plugs as with the standard ignition or is there a better option? What about gap? Thanks for any advice.
Jeff
'64 swb stepside (gone) '57 1 ton '53 phone truck '59 swb '46 1 1/2 ton '68 swb gmc
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | I'm putting a pertronix ignition on a 292 I6. The Pertronix website says not to use solid core wires but they don't have a recommendation about plugs. Should I use the same plugs as with the standard ignition or is there a better option? Thanks for any advice.
Jeff From the Petronix website: What applications are covered with the PerTronix Flame-Throwerâ„¢ spark plug wires? Flame-Thrower spark plug wires are the perfect companions to our other performance products. Many applications are covered, but they are broken into two basic types. For those interested in stock appearance, our 7.0 mm "STOCK-LOOK"â„¢ all black (no script) wires are available. Not concerned about looking stock? Our 8.0 mm "MAGx2"â„¢ colored wires with Flame-Throwerâ„¢ white letter script, do the trick.http://www.pertronix.com/prod/ig/flame/wires/default.aspx(other, similar type plug wires would also work) | | | | | Joined: Apr 2005 Posts: 7,440 Bolter | | Bolter Joined: Apr 2005 Posts: 7,440 | I think some folks open the plug gap up a bit.
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | | | |
