1 members (2-Ton), 133 guests, and 1 robot.
Topics128,114
Posts1,056,287
Members48,439
#1180454 08/30/2016 3:28 PM
I'm putting a pertronix ignitor II ignition on a 292 I6. The Pertronix website says not to use solid core wires but they don't have a recommendation about plugs. I emailed them but got no response. Should I use the same plugs as with the standard ignition or is there a better option? What about gap? Thanks for any advice.
Jeff
'64 swb stepside (gone)
'57 1 ton
'53 phone truck
'59 swb
'46 1 1/2 ton
'68 swb gmc
Originally Posted by jfnar
I'm putting a pertronix ignition on a 292 I6. The Pertronix website says not to use solid core wires but they don't have a recommendation about plugs. Should I use the same plugs as with the standard ignition or is there a better option? Thanks for any advice.
Jeff
From the Petronix website:
What applications are covered with the PerTronix Flame-Throwerâ„¢ spark plug wires?
Flame-Thrower spark plug wires are the perfect companions to our other performance products. Many applications are covered, but they are broken into two basic types. For those interested in stock appearance, our 7.0 mm "STOCK-LOOK"â„¢ all black (no script) wires are available. Not concerned about looking stock? Our 8.0 mm "MAGx2"â„¢ colored wires with Flame-Throwerâ„¢ white letter script, do the trick.
http://www.pertronix.com/prod/ig/flame/wires/default.aspx
(other, similar type plug wires would also work)
I think some folks open the plug gap up a bit.
"In most cases increasing the factory recommended gap by .005 improves the engine performance."
