9 members (Bizaircon, Youngin' Tut 59, klhansen, J Lucas, Hotrod Lincoln, 5 Window 9434, lumbersawyer, DougH6100, 1 invisible),
78
Mod | | | Forums66 Topics128,139 Posts1,056,762 Members48,454 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2005 Posts: 14 New Guy | | New Guy Joined: Oct 2005 Posts: 14 | My 1956 3800 dually has " 443 J " as the paint code. What color is that? | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | the only commercial [truck] codes I've ever seen for the standard factory colors in the TF years are 200, 500, and 700 series numbers - you may have one that came w/ a special order color, and the only way you'll find it will be to find a complete list of all color numbers GM used around then - can you get a close idea from the firewall or door edges or behind the gas tank? was a pretty limited range if it was a standard color
Bill | | | | | Joined: Oct 2005 Posts: 14 New Guy | | New Guy Joined: Oct 2005 Posts: 14 | Bill,
Thanks for the info on 1957. I will look this week when I go to my farm where I keep the truck. | | |
