BUSY BOLTERS Are you one? The Shop Area
| | Click on image for the lowdown.
0 members (),
525
robot. | Key: Admin,
Mod | | Forums66 Topics126,777 Posts1,039,270 Members48,100 | Most Online2,175 Jul 21st, 2025 | | | Joined: Aug 2016 Posts: 4 Moderated | Moderated Joined: Aug 2016 Posts: 4 | Hi, I am new to the forum and love reading the topic. What a wealth of knowledge.
I have a 1950 GMC 1 Ton Stake body pickup and was wondering if anyone knew of another owner in the USA that had the same truck? I have been looking for years and haven't really found any.
If you know of another owner, would love to connect with them.
I have been trying to replace the metal rails around the outside of the truck but all I get is 'Good Luck".
Thanks George
George Ishee
| | | | Joined: Jun 2011 Posts: 1,901 Shop Shark | Shop Shark Joined: Jun 2011 Posts: 1,901 | I think that's about all you can expect... Time for new metal working tools so you can fab your own.
| | | | Joined: Sep 2011 Posts: 131 Shop Shark | Shop Shark Joined: Sep 2011 Posts: 131 | I need to put a metal side rail around my new reproduction wooden deck on our 55 one ton. The rotten old grain box was removed and burned by the farmer and the steel items were scrapped!!! I have access to old out of service school bus parts and the rolled steel outside barrier strips that are on all buss body's seem to be close to the correct size and profile. Grind the heads off the retaining rivets and presto side trim for our decks. Every scrap yard probably has them and they are cheap-- like me.
Good luck with the deck.
1 1955 Chev one ton. 261 engine
3 1962 Chev c-10 261 engine 4 1966 Plymouth VIP 5.7 GenIII Hemi 5 1966 Imperial Crown Coupe 440 engine | | | | Joined: Jun 2011 Posts: 1,901 Shop Shark | Shop Shark Joined: Jun 2011 Posts: 1,901 |
| | | | Joined: Apr 2016 Posts: 102 'Bolter | 'Bolter Joined: Apr 2016 Posts: 102 | 1950GMC Guy, I have a 48 3/4 ton chevy with a stake bed on it. by the looks of it, I believe it was built in the 40's or 50's. Still new enough to be figuring out the pics...will post some soon. | | | | Joined: Apr 2016 Posts: 102 'Bolter | 'Bolter Joined: Apr 2016 Posts: 102 | first attempt at pics Four bed pics to see.
| | | | Joined: Dec 2011 Posts: 402 Shop Shark | Shop Shark Joined: Dec 2011 Posts: 402 | | | | | Joined: Aug 2016 Posts: 4 Moderated | Moderated Joined: Aug 2016 Posts: 4 | Thanks Howie, I think I am just going to build it out of wood first. It will be about $300 in wood so if it doesn't work then I will go the next route. Thanks for the advice.
George Ishee
| | | | Joined: Apr 2004 Posts: 5,139 Authorized Pest | Authorized Pest Joined: Apr 2004 Posts: 5,139 | Check the search feature (the one from the menu at the very top of the page and the very bottom of the page; not the search for the forum). I found quite a few GMC stake body trucks. Some are big; some 1/2-ton. Many are trucks in the Gallery and some are posts in the forum. One guy was just about to start his stake body on his GMC 1/2-ton.
~ Peggy M 1949 Chevrolet 3804"Charlie" - The Stovebolt FlagshipIn the Gallery || In the Gallery Forum"I didn't see this one coming. I don't see much of anything coming. :-O" | | | | Joined: Nov 2008 Posts: 544 Shop Shark | Shop Shark Joined: Nov 2008 Posts: 544 | I have a 1949 3800 Chevrolet Cab/chassis. I believe that my truck bed was a homebuild or aftermarket. A good metal fabricator should be able to fix you up. | | |
