| | | Forums66 Topics128,212 Posts1,057,463 Members48,471 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2016 Posts: 83 Shop Shark | | Shop Shark Joined: May 2016 Posts: 83 | I got the owner of the truck to send me a pic of the data tag on the driver's door frame.... It tells all: http://i668.photobucket.com/albums/vv44/camarohunter8/Red%20Truck/xxx4%20-%20Copy_zpsyk4ymd0c.jpg16,000 lbs Max Gross Weight Serial number 5UYG Translates to: Model 6500 or 6500S 2 ton 179" wheelbase Built July 1951 (a '51 model) in KC, Mo. Powered by a 105hp 235 cuin Loadmaster inline 6 Looks like there were 23,850 total units built This is a BIG bolt, Brothers and Sisters.....
| | | | | Joined: Oct 2002 Posts: 4,066 Bolter | | Bolter Joined: Oct 2002 Posts: 4,066 | Redryder pixMy HotrodA veteran - whether active duty, retired, national guard, or reserve - is someone who, at one point in his or her life, wrote a blank check made payable to The 'United States of America', for an amount of "up to and including my life."I am fighting cancer and I am winning the fight | Pain is part of life; misery is an option. | | | | | Joined: May 2016 Posts: 83 Shop Shark | | Shop Shark Joined: May 2016 Posts: 83 | | | | | | Joined: Dec 2002 Posts: 2,549 'Bolter | | 'Bolter Joined: Dec 2002 Posts: 2,549 | Congratulations. Not as many long wheelbase 6500 series trucks floating around, as there are 6400 series trucks. That's the only difference in the two, is the wheel base. | | | | | Joined: Mar 2004 Posts: 6,236 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,236 | Where did you come up with the production numbers? Mike B  | | | | | Joined: May 2016 Posts: 83 Shop Shark | | Shop Shark Joined: May 2016 Posts: 83 | Where did you come up with the production numbers? Mike B  http://www.caaarguide.com/sub1/id392.html I might be wrong, Mike. But I took the last number in the line to be total production, tho it might only be a partial. That part of the chart is not very easy to understand (at least it's not to me, DOH!). | | | | | Joined: Mar 2004 Posts: 6,236 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,236 | I believe those numbers are values, not production numbers. To the best of my knowledge there are no production figures available for our trucks. Mike B  | | | | | Joined: May 2016 Posts: 83 Shop Shark | | Shop Shark Joined: May 2016 Posts: 83 | I believe those numbers are values, not production numbers. To the best of my knowledge there are no production figures available for our trucks. Mike B  What kind of values, Mike? What kind of value would be 23,850? I just thought it HAD to be a prod number especially since it was in the prod column....But then again, I've been wrong many times before.... | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | If it is a 6500 series, there were: - around 4800 made in 1950 (1% of trucks produced) and - around 9000 made in 1952 (3% of trucks produced) and - around 8400 made in 1953 (3% of trucks produced).
Those number are supposedly for calendar year, not for model year.
I have not seen any other Advance-Design year's production numbers. | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | that site is an appraisal site, the last columns [S, 2,4,6,8,10] as explained are values, the "PROD" column is blank [unknown, as Mike sez] .... so yes, $23,850 would be "appraised value" for a condition 10 truck Bill | | | | | Joined: May 2016 Posts: 83 Shop Shark | | Shop Shark Joined: May 2016 Posts: 83 | that site is an appraisal site, the last columns [S, 2,4,6,8,10] as explained are values, the "PROD" column is blank [unknown, as Mike sez] .... so yes, $23,850 would be "appraised value" for a condition 10 truck Bill Oh, ok! I see! I understand now. Thanks very much Bill for setting me straight! The chart makes perfect sense now. | | |
