3 members (baldeagle, moparguy, KEVINSKI), 123 guests, and 0 robots.
Topics128,211
Posts1,057,468
Members48,471
I got the owner of the truck to send me a pic of the data tag on the driver's door frame.... It tells all:
http://i668.photobucket.com/albums/vv44/camarohunter8/Red%20Truck/xxx4%20-%20Copy_zpsyk4ymd0c.jpg
16,000 lbs Max Gross Weight
Serial number 5UYG
Translates to:
Model 6500 or 6500S
2 ton
179" wheelbase
Built July 1951 (a '51 model) in KC, Mo.
Powered by a 105hp 235 cuin Loadmaster inline 6
Looks like there were 23,850 total units built
This is a BIG bolt, Brothers and Sisters.....
I nailed it..lol
Redryder pix
My Hotrod
Originally Posted by joker
I nailed it..lol
Indeed you DID, Brother!
Congratulations. Not as many long wheelbase 6500 series trucks floating around, as there are 6400 series trucks. That's the only difference in the two, is the wheel base.
Spanky Hardy
More pictures on Photobucket
1950 GMC 250 1-Ton
Where did you come up with the production numbers?
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
Mike B smile
http://www.caaarguide.com/sub1/id392.html I might be wrong, Mike. But I took the last number in the line to be total production, tho it might only be a partial. That part of the chart is not very easy to understand (at least it's not to me, DOH!).
I believe those numbers are values, not production numbers. To the best of my knowledge there are no production figures available for our trucks.
Mike B smile
Mike Boteler
1984 Jeep CJ7
Silver Spring, MD
Mike B smile
What kind of values, Mike? What kind of value would be 23,850? I just thought it HAD to be a prod number especially since it was in the prod column....But then again, I've been wrong many times before....
If it is a 6500 series, there were:
- around 4800 made in 1950 (1% of trucks produced) and
- around 9000 made in 1952 (3% of trucks produced) and
- around 8400 made in 1953 (3% of trucks produced).
Those number are supposedly for calendar year, not for model year.
I have not seen any other Advance-Design year's production numbers.
that site is an appraisal site, the last columns [S, 2,4,6,8,10] as explained are values, the "PROD" column is blank [unknown, as Mike sez] .... so yes, $23,850 would be "appraised value" for a condition 10 truck
Oh, ok! I see! I understand now. Thanks very much Bill for setting me straight! The chart makes perfect sense now.
