| | | Forums66 Topics128,022 Posts1,055,386 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2016 Posts: 196 'Bolter | | 'Bolter Joined: Jul 2016 Posts: 196 | hi guys, im looking to put a crate motor in my 61 apache. now is 6 cylinder with 3 on the tree. will the tranny fit behind the crate( small block)?
1961 apache
| | | | | Joined: May 2005 Posts: 1,624 Shop Shark | | Shop Shark Joined: May 2005 Posts: 1,624 | The cheapest crate engine is the 290 hp 350ci which can be had for less than $2000.00 is you look around. I purchased mine from a Chevy for around $1900.00. Four bolt main and till now solid as a rock. Additional costs for adding carb, intake and such. Should bolt right up. I needed block hugger headers, new motor mounts and so on.
| | | | | Joined: Jul 2014 Posts: 186 'Bolter | | 'Bolter Joined: Jul 2014 Posts: 186 | I got mine for 1400 from Jegs. | | | | | Joined: Sep 2013 Posts: 52 Shop Shark | | Shop Shark Joined: Sep 2013 Posts: 52 | Great way to go. Easy to mod up and reliable. I' m well into my second season on the road since we finished swapping my six for a GM crate - very happy.
| | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | I agree the GM crate engine is the way to go. In answer to your question, the engine will not fit your 6 cyl. bell housing but the trans will work with the proper bell housing. The bell housing from a 55 up v-8 will work. You probably have a hydraulic clutch linkage. Finding a bell housing with the clutch arm on the right hand side for the hyd. cyl. is very difficult. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Apr 2005 Posts: 2,097 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,097 | The standard GM crate engine is rated 260 Hp provided you use the recommended manifolds, carb, etc. As mentioned they can be had for about $1400 shipped. You will still need all the accessories which could add another $1000 depending on what your preferences are. The 290 HP can run more. I have installed several of them and believe it is a good option. Fred
| | | | | Joined: May 2005 Posts: 1,624 Shop Shark | | Shop Shark Joined: May 2005 Posts: 1,624 | For some reason I thought the small v8 would bolt up to the tranny. "Wrenchbender Ret." has it right. Sorry for the confusion.
| | | | | Joined: Sep 2013 Posts: 52 Shop Shark | | Shop Shark Joined: Sep 2013 Posts: 52 | The low starting price (I paid $1259 to Jegs on an Ebay special) is about half of what you will need to get thst 260hp - add manifold, carb, headers,(possibly) cast valve covers, dist, water pump, fuel pump, brackets, plug wires & so on & the price can double... If you want a bit more HP & cool factor = more $. I added a modest grind roller cam, roller lifters & rockers, ported the heads & topped it with tri-power. Not a radical change and it's reliable, economical & fun.
Ditto on the bellhousing posts - a repop 3899621 V8 bellhousing (For 168 tooth flywheel, 11" clutch, 4-5/8" bearing retainer) and worked nicely for me. Works with Muncie, Tremec & B-W - I think a T5 works too. | | | | | Joined: Sep 2011 Posts: 131 Shop Shark | | Shop Shark Joined: Sep 2011 Posts: 131 | The modern way is to find a wrecked 2wd truck or van and get a new style fuel injected GM SL engine and overdrive trans. The small blocks were good but it is 2016! Newer wrecking yard stuff is way cheaper, has lots of life and one donor for all the stuff.
It worked great for me in my Ply----h. A lot more jam and better fuel mileage.
1 1955 Chev one ton. 261 engine
3 1962 Chev c-10 261 engine 4 1966 Plymouth VIP 5.7 GenIII Hemi 5 1966 Imperial Crown Coupe 440 engine | | |
