1 members (Gray_Ghost), 157 guests, and 0 robots.
Topics128,195
Posts1,057,369
Members48,469
#1179290 08/22/2016 10:56 PM
rodscustomstrucks has a Mustang II hub to hub kit on Ebay for what seems like a decent price, featuring Heidts crossmember and other made in USA parts.
Anyone familiar with this seller or have any first hand experience with his kit?
He has excellent feedback on Ebay.
http://www.ebay.com/itm/HEIDTS-1947...RUCK-MUSTANG-II-HUB-TO-HUB-/321713251816
Ralph
Sounds like a complete ready to install kit. Heidts is a reputable builder. The seller shows 1550 sales and a 100% positive feedback. I can't comment on the price, I just don't know but the seller seems to be on the up and up.
Good price, looks like everything you will need. Opt for the power steering, drop spindles.
Looks like a pretty comprehensive kit for the money.
Tubular upper and lower control arms and a sway bar too.
I paid far too much for a basic MII,pressed stock arms,no sway bar etc here in the UK and it cost a lot more than that nearly ten years ago.
More pix on Flickr.
Thanks for the replies guys. I think I will pull the trigger on this one. I need to narrow the track on my truck. Currently there is a C10 crossmember and suspension bolted on.
Does anyone know the track width of the Mustang II set up? Im finding conflicting info.
Ralph
Im new here, as a matter of fact, this is my first reply. However, i caution you on the e bay kits. While some are what they seem, others are "heits" crossmembers and " miss matched controll arms ect. A buddy of mine bought a similar kit to the one your discribing, and did make it work, but had to redrill wholes after assembly to even get remotely close to alignment specs. Make sure all components are from the same manufacturers. I bought my Heidts kit from Speedway, for around 1400$ .....no problems
3window 51
82 k10
Kit looks complete/good quality. Track width is a good question few address. Lowering these trucks is all about "profiling" and not as much thought to other appearance issues and handling. Seller should give you track width measured by wms to wms (wheel mounting surface). Stock is around 56.5". Most (but not all) mustang ll kits use the same dimension. More often than not, this will give the front tires a sucked in look - which seems to be what most people settle for. Opting out of this look is possible, but often at a higher price point (like Scott's), look at all the manufactures & compare.
Thanks guys. Havent decided yet!
Ralph
