3 members (Ponchogl, DadsFirstPickup, Otto Skorzeny), 204 guests, and 5 robots.
Topics128,107
Posts1,056,225
Members48,436
#1179763 08/26/2016 12:26 AM
Hey, got a question, how would an anti sway bolt up on my posie front leaf springs w/ just 2 leafs on a 53 chevy half ton? I have no experience with a sway bar install. Are they designed to fit only the original leafs? I want one and if one bolts right up to my mostly original front suspension, I want it.
[url=http://www.stovebolt.com/gallery/shannon_joe_1953.html]1953 Chevy 3100[/ur When life looks like easy street there is danger at your door
why do you want one
Redryder pix
My Hotrod
A sway bar bolts to the axle and the frame, not to the springs.
Here is a original Sway Bar
The ant-sway bar I got from CPP came with brackets that are sandwiched between the axle and spring. The sway bar then mounts to the bracket. Because of that, it doesn't matter how many springs you have. If you ad a sway bar you'll love the improvement.
Jorb,
Hopefully, Bill's has more than 1. I purchased that one.
Unless you don't care about period correct, the after market sway bars are a little
thicker and my guess, perform better.
Also a thumbs up to Bill's, no issues what-so ever!!
Jim
~ Jim Schmidt, Bucks County, PA
1953 Chevrolet 3804 1-ton
In the DITY Gallery
