| | | Forums66 Topics128,108 Posts1,056,227 Members48,436 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2007 Posts: 51 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2007 Posts: 51 | Hey, got a question, how would an anti sway bolt up on my posie front leaf springs w/ just 2 leafs on a 53 chevy half ton? I have no experience with a sway bar install. Are they designed to fit only the original leafs? I want one and if one bolts right up to my mostly original front suspension, I want it.
[url=http://www.stovebolt.com/gallery/shannon_joe_1953.html]1953 Chevy 3100[/ur When life looks like easy street there is danger at your door
| | | | | Joined: Oct 2002 Posts: 4,066 Bolter | | Bolter Joined: Oct 2002 Posts: 4,066 | Redryder pixMy HotrodA veteran - whether active duty, retired, national guard, or reserve - is someone who, at one point in his or her life, wrote a blank check made payable to The 'United States of America', for an amount of "up to and including my life."I am fighting cancer and I am winning the fight | Pain is part of life; misery is an option. | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | A sway bar bolts to the axle and the frame, not to the springs. | | | | | Joined: Mar 2011 Posts: 1,146 Shop Shark | | Shop Shark Joined: Mar 2011 Posts: 1,146 | Here is a original Sway Bar
| | | | | Joined: Nov 2009 Posts: 639 'Bolter | | 'Bolter Joined: Nov 2009 Posts: 639 | The ant-sway bar I got from CPP came with brackets that are sandwiched between the axle and spring. The sway bar then mounts to the bracket. Because of that, it doesn't matter how many springs you have. If you ad a sway bar you'll love the improvement. | | | | | Joined: Feb 2013 Posts: 614 'Bolter | | 'Bolter Joined: Feb 2013 Posts: 614 | Jorb, Hopefully, Bill's has more than 1. I purchased that one. Unless you don't care about period correct, the after market sway bars are a little thicker and my guess, perform better. Also a thumbs up to Bill's, no issues what-so ever!! Jim | | |
