8 members (68ironhead, lumbersawyer, 48jim1ton, Woodcmiami, 3B, J Lucas, Ponchogl, 1 invisible),
97
0
Mod | | | Forums66 Topics128,049 Posts1,055,553 Members48,425 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#11797 12/27/2002 4:45 AM | Joined: Oct 2000 Posts: 98 'Bolter | | 'Bolter Joined: Oct 2000 Posts: 98 | I came into the possession of a Saginaw 4 speed today. (Christmas as day late. At least I think it is.) It has 3 grooves on the input shaft, so that means 1st gear is 3.50. I was thinking of putting it into my 1966 Chevy which has a 250 6 cylinder. The only problem that I see so far is that the shifter levers on the transmission are not there. So, a couple of questions....
Can you purchase these somewhere? Or do you just have to do some junk yard searching?
What shifter would work best for my situation?
Thanks for your help in advance. Mike
Mike Kelley 1966 Chevy C10 SWB - 250 L6/S10 T5 2002 Chevy Ext 1500 4x4
Http://myol66.wordpress.com
#11798 12/27/2002 6:55 AM | Joined: Jul 2002 Posts: 68 Member | | Member Joined: Jul 2002 Posts: 68 | I have a 4 sp Saginaw in my '54. It has a old Hurst shifter on it that works OK. There a little tricky to adjust, so maybe someone here will have a different option. You might try Patrick's in AZ.for the shifter linkage or start searching the bone yards. Good luck.
'54 3100-235-T5 trans-12 bolt 3:31 '68 Impala 307/350 '78 Sportster/Original owner
#11799 12/27/2002 3:46 PM | Joined: Jan 2001 Posts: 687 Shop Shark | | Shop Shark Joined: Jan 2001 Posts: 687 | Hi,
I was going to put a saginaw 4 speed in my 1966 Chevrolet stepside - with 3.07 rear gears. If you have a bench seat, then you'll have to buy (or make) a bench seat shifter handle. Hurst makes one that's sold through Summit, among other vendors. But it's expensive (about 165 for the shifter and handle alone - plus linkages).
If I were you I'd check Ebay. Hurst 4 speed shifters are sold there daily (and fairly cheap). The Hurst shifter handles are often interchangeable so you may be able to buy a good shifter and find a usable truck bench shifter later. Just an FYI, the popular 55-57 car bench seat shifter will probably be too short to clear the seat.
-ftyler | | |
#11800 12/28/2002 1:12 AM | Joined: Oct 2000 Posts: 98 'Bolter | | 'Bolter Joined: Oct 2000 Posts: 98 | ftyler,
What engine do you have in your truck? I have a 3:07 rear end to put in place of the current 3:73 rear end. I got the Saginaw 4 speed to replace the 3 speed Saginaw. I have a 250 6 cylinder and have been told that the 3:07 would be too high a ratio for this engine. Was wondering if the 4 speed would make it more tolerable.
Thanks for replying. Mike K.
#11801 12/28/2002 6:12 AM | Joined: Jan 2001 Posts: 687 Shop Shark | | Shop Shark Joined: Jan 2001 Posts: 687 | That's a really good combination (saginaw 4 speed and 3.07 rear end). I think the 2.85 or 3.11 first gear saginaw box would be optimal because the gear spread isn't as wide and acceleration would be slightly better.
The 3.07 is too high for a 250 with a 3 speed. The drop in rpms between upshifts would make your truck useless for towing, hauling and acceleration would suffer greatly.
I have almost the exact same setup as you, except my engine is a 230. I bought a 3.07 rear end and a saginaw 4 speed to replace my 3.73/3-speed. Then I came across a GM 4 speed transmission with 0.73 overdrive. I liked the idea of making one swap instead of two. And I'd actually end up with a lower final drive ratio (2.72). So I sold the 3.07 (still have the saginaw).
While I was at it I decided to build a 292 to go behind the new tranny. Might as well do it all at once. The engine is almost finished. It's just a mild cam and flywheel away from being complete. 292 bored .060 over, 500 cfm 4 barrel, headers, HEI. Should be a great performer when finished.
-ftyler | | |
