| | | Forums66 Topics128,051 Posts1,055,768 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2014 Posts: 33 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2014 Posts: 33 | Does anyone know if a Powerglide tranny from a 1957 235 ci engine would fit to a 1953 gmc 228 engine. I don't know what vehicle it came from but is supposed to be in working condition and the price of $75 seems like a good deal. I figure there's enough experts here to have and answer. Thanks. | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | The transmission should bolt up to the block but I don't know if the flexplate will bolt to the crank. I'm assuming it uses a flexplate. | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Does the GMC 228 have a 4 bolt flywheel-crank connection?
I think that Chevrolet 216/235/261 all had 6 bolt flywheel-crank connections. | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | I think all 228s were 4 bolt. The '54 and later 248s were 6 bolt. But according to Hollander, they won't interchange with Chevrolet. | | | | | Joined: Feb 2004 Posts: 29,771 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,771 | A 1st. generation Powerglide has two speeds- - - -"too low" and "too high". It's also made of cast iron, which makes it ridiculously heavy. Add to that a notoriously inefficient torque converter, and the burning question would be "Why do you want one?" For about the same cost as making the P/G work, you could adapt a 700R4 and have 4 speeds, including overdrive, and a lockup clutch in the torque converter that's almost like a 5th. gear ratio. Jerry
| | | | | Joined: Apr 2014 Posts: 33 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2014 Posts: 33 | Thanks for all the replies. I currently have a 4 speed stick, I think it's a SM420, that my wife can't operate so I was thinking an automatic. I must confess I know squat about trannys but the 700R4 suggested by Jerry sounds interesting. I'll have to do a little more reading and research on the subject. | | | | | Joined: Feb 2011 Posts: 583 'Bolter | | 'Bolter Joined: Feb 2011 Posts: 583 | I had a powerglide behind a 1956 235 stovebolt, another behind a 1960 235 stovebolt, another behind a 1956 with a 350 v8, and yet another behind a 1966 396 v8. They took all the punishment I could give them back then. I also agree that I would rather have a more modern setup. And yes, them babies were quite heavy.
Rick
1939 Chevrolet Stake Truck
| | | | | Joined: Feb 2004 Posts: 29,771 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,771 | In the mid-1960's the PG got redesigned- - -aluminum case, a lot more rugged, and more efficient, but still only two speeds. Those transmissions got snapped up by the drag racers and sprint car guys, so they're pretty scarce now. Jerry
