2 members (Steveoreno, 1 invisible),
126
Mod | | | Forums66 Topics128,269 Posts1,058,402 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2006 Posts: 1,154 Shop Shark | | Shop Shark Joined: Dec 2006 Posts: 1,154 | Our 54 3100 has all its original gauges. They all work except the gas gauge. The trucks been converted to 12 volt. The PO took the sender out of the tank and threw it away. From what I have read it's a 30ohm that's what I ordered and instead of using a runtz I purchased a 12volt gauge quadrant. Is there anything I need to know about installing this gauge that will make it easier? I see a hole in the floor with a grommet is that how the wire is routed to the gauge? Gas tank is behind the seat any help is always appreciated and thank you. Steve | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | Don't trust that the tank is grounded to the truck. Run a dedicated ground from one of the sender mounting screws to the cab. | | | | | Joined: Dec 2006 Posts: 1,154 Shop Shark | | Shop Shark Joined: Dec 2006 Posts: 1,154 | Thanks that's a real good tip. The tank is on some kind of tar paper so that may effect the grounding. I'll run a separate ground wire.
| | | | | Joined: Jan 2016 Posts: 1,110 'Bolter | | 'Bolter Joined: Jan 2016 Posts: 1,110 | I have a 54 3100 I just completed replacing the gauge with a 12v gauge and replaced the sender. Yes, my sender unit wire goes through a hole in the floor. My gauge had some strange behavior until it was completely installed and the ignition turned on to apply power to the gauge. Ground is critical, as cletis pointed out. | | | | | Joined: Dec 2006 Posts: 1,154 Shop Shark | | Shop Shark Joined: Dec 2006 Posts: 1,154 | Wow....I never realized ground was so important for these gauges. After the wire goes through the hole how did you route it to the gauge? Also what was your technique for installing the gauge quadrant ? | | | | | Joined: Jan 2016 Posts: 631 'Bolter | | 'Bolter Joined: Jan 2016 Posts: 631 | Reality is .......ground connection..........is critical in every circuit, not just gauges. | | | | | Joined: Dec 2006 Posts: 1,154 Shop Shark | | Shop Shark Joined: Dec 2006 Posts: 1,154 | You are most correct...I have grounded myself out on a spark plug....it was shocking to say the least! You only do it once. | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | Yep, I touched a bare connection from the coil and it slammed me against the one. One time is one more than enough. | | | | | Joined: Mar 2010 Posts: 10,335 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,335 | How is the cab grounded to the frame/battery? Cab mount bolts?
| | | | | Joined: Dec 2006 Posts: 1,154 Shop Shark | | Shop Shark Joined: Dec 2006 Posts: 1,154 | Got that covered two grounding straps cab frame and starter battery...my 90 year old uncle had me do that he said it was the thing to do back in the day. ...Carl you haven't mentioned any secrets to putting in the gas gauge ...come on give them up! | | | | | Joined: Mar 2010 Posts: 10,335 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,335 | Who, The factory location of the fuel sender ground is the bottom of the cab (outside of the cab) under a wire clip held on by a nut and bolt (the bottom of the cab originally may have had some red oxide primer if any coating at all). Since the cabs originally did not have a ground strap going to the cab, I am guessing that the cab mount bolts provided the cab ground. Fast forward 60 years, where we epoxy prime and thoroughly paint every part to prevent rust, we may be losing adequate cab grounding. As far as "secrets" to putting in the gas gauge, it helps if you have extra elbows in your arms.  Carl
| | | | | Joined: Dec 2006 Posts: 1,154 Shop Shark | | Shop Shark Joined: Dec 2006 Posts: 1,154 | Thanks Carl...no xtra elbows and a fat head to boot! Looks like hell under there ...maybe it's a job for a younger mechanic with xtra elbows and a back that can bend! I'm in my rusting years! | | | | | Joined: Feb 2008 Posts: 1,135 'Bolter | | 'Bolter Joined: Feb 2008 Posts: 1,135 | A suggestion on working under the dash might help? One of my buddies suggested I build a simple plywood platform with a thin pad to span the floor board area. It worked like a charm for laying on my aching back while fixing a rats nest of wires a PO had made. It was comfy enough, I might have even bagged a few z's a time or two. | | | | | Joined: Dec 2006 Posts: 1,154 Shop Shark | | Shop Shark Joined: Dec 2006 Posts: 1,154 | Hey now that using your head to save your back? Plus you can bag a few zzz' and the wife will never know. Just looking up into all those wires will give you nightmares though....l | | |
