1 members (‘37ChevyPU),
86
Mod | | | Forums66 Topics128,211 Posts1,057,476 Members48,473 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2016 Posts: 5 New Guy | | New Guy Joined: Aug 2016 Posts: 5 | As I stated in my intro in the new member forum, I have been working on a '46 1/2 ton truck that has not run for many years. With guidance from a member, I was able to find a replacement rear yoke from North Western Transmission and get the drive line back together. I also replaced the rear transmission mounts, they were dry rotted and pulling apart. I thought after replacing those mounts, the clutch chattering that I have would go away but it looks like I need to remove the trans and investigate what is worn out. I have read stories to look for a worn pilot bearing as well as oil soaked clutch disk. I'll let you know what I find.
| | | | | Joined: Dec 2015 Posts: 2,063 Big Bolt Forum Moderator | | Big Bolt Forum Moderator Joined: Dec 2015 Posts: 2,063 | welcome to the site! You might also find a loose input shaft, caused by worn out bearings. | | | | | Joined: Mar 2008 Posts: 374 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 374 | | | | | | Joined: Aug 2016 Posts: 5 New Guy | | New Guy Joined: Aug 2016 Posts: 5 | Greetings, I have not set up an account yet for pictures, when I do, I'll post a few. I have many projects going on and at this point I really do not have the time to continue to work on it. Besides clutch work I want to install a complete new wiring harness. The original on is in such sad shape I am afraid some of the wires could arc together and start a fire. Does anyone have a suggestion of a drop-in harness and still keep the 6 volt generator? | | |
