2 members (Stovebolt48, 1 invisible), 131 guests, and 2 robots.
Topics128,211
Posts1,057,473
Members48,473
As I stated in my intro in the new member forum, I have been working on a '46 1/2 ton truck that has not run for many years. With guidance from a member, I was able to find a replacement rear yoke from North Western Transmission and get the drive line back together. I also replaced the rear transmission mounts, they were dry rotted and pulling apart. I thought after replacing those mounts, the clutch chattering that I have would go away but it looks like I need to remove the trans and investigate what is worn out. I have read stories to look for a worn pilot bearing as well as oil soaked clutch disk. I'll let you know what I find.
Big Bolt Forum Moderator
welcome to the site! You might also find a loose input shaft, caused by worn out bearings.
Mike
Post some pics!
1946 Chevrolet 1/2-ton
More pix on Photobucket
Greetings, I have not set up an account yet for pictures, when I do, I'll post a few. I have many projects going on and at this point I really do not have the time to continue to work on it. Besides clutch work I want to install a complete new wiring harness. The original on is in such sad shape I am afraid some of the wires could arc together and start a fire. Does anyone have a suggestion of a drop-in harness and still keep the 6 volt generator?
