3 members (Dennys28, Phak1, Biermann), 128 guests, and 4 robots.
Topics128,165
Posts1,056,987
Members48,458
I have a 55ist series 3100 pickup with three speed on the column. I am occasionally having trouble shifting from ist to second gear as it occasionally lock up. I want to pull out my shift box and have it restored. I hear jim carter offers this service. what do I have to do to remove the shift box. easy project? thanks in advance for any help/suggestions. jim
yes it's easy to remove, but also easy to fix it up yourself, maybe without taking it completely off, might just be slipped connections of the rods to the trans, start with taking the top off and clean and re-grease it - have someone carefully run the shifter and watch how it moves, look at the notches and pawls for wear, should be fairly square corners, if too rounded they can be built up with a bit of weld and filed back to shape
