1 members (Hotrod Lincoln),
104
Mod | | | Forums66 Topics128,089 Posts1,056,004 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2016 Posts: 236 DLBrooks | | DLBrooks Joined: Jun 2016 Posts: 236 | http://67-72chevytrucks.com/vboard/showthread.php?p=7688972#post7688972But need some help. The frame is a 1946 3/4 or a ton, cab is a 41 from a 1 1/2 ton. The steering column tube is about 2 to 2 1/2 inches too low for the tube perch. I see no clocking adjustment on the steering gear housing. I have the cab mounted in the correct holes, all appears where it looks like it should. See last picture.
| | | | | Joined: Dec 2007 Posts: 210 Shop Shark | | Shop Shark Joined: Dec 2007 Posts: 210 | I don't know the answer to your problem.i have all of that apart on my truck ,but don't remember how it all bolted on.will the steering box rotate where it is bolted to the frame? Like I said I just can't remember how it all works. Your truck looks good and is a little farther along that mine. I added a IFS to mine with a power rack,so I won't be using the stock steering column.I see you are in ohio also , I am in the south east to the ohio river. | | | | | Joined: Apr 2004 Posts: 888 'Bolter | | 'Bolter Joined: Apr 2004 Posts: 888 | Here is a picture of my 46 3/4 ton interior with the original steering drop. It measures 2 1/8" on center from dash. There is also a brace that attaches from column drop to firewall to stiffen/support. Hope this helps. Have fun and good luck Dan
| | | | | Joined: Jun 2016 Posts: 236 DLBrooks | | DLBrooks Joined: Jun 2016 Posts: 236 | You guys are correct and thanks. Loosen the two top of frame bolts and it pivots easily. Done. | | |
