7 members (Charles in CA, Hanks custodian, 48ed56pam, Ponchogl, Bill Marlow, frogfarmer, 2-Ton), 193 guests, and 0 robots.
Topics128,081
Posts1,056,071
Members48,434
#1178237 08/15/2016 3:24 AM
Ten years ago i acquired this truck. It has been parked under a roof since 1983. Rusting is pretty severe on the areas closer to the ground, including the front of the frame.
When I drug it out of the shed a few weeks ago I did manage to get it into neutral and the wheels all turn. I am assuming the clutch is engaged since I have not attempted to disengage it and the crank can be turned by hand on the front pulley. It was running when it was parked so i assume there isn't much major damage to the powertrain/driveline.
My plan is to take it completely down to the frame and build it back up, provided the frame isn't a complete loss. I have never attempted anything like this before, but I am confident I can make it happen. A man once told me you can make anything run if you have enough money. Not sure I have that much money, but hopefully I do.
Click here for the Google drive folder with pictures. I plan to take as many as possible during teardown and rebuild. My main concern at this point will be advice concerning body panel repair or replacement. Is it repairable? Should I replace with a reproduction panel or should I try to find original body panels in decent condition? Are there cheap fixes using generic pieces of metal, (bed cross sills; etc.). The mechanical side I will be alright with for the time being. I am a mechanic by trade, not an automotive mechanic, but a mechanic nonetheless. I could use some advice about where to find a legit service manual for this model truck.
Wish me luck and feel free to offer any useful advice or helpful hints.
1961 Chevy Apache 10 Stepside 235 CI straight 6 Three on the tree.
Good luck and welcome.
~ HB
1962 Chevrolet C10
1962 Suburban
Engine number is F0323J so if I am reading things right it is definitely a 235 CI straight six.
Thanks Hambone.
Yes - truck 235 (1/2 ton through 1 ton with manual transmission)
I got the seat and fuel tank out of the cab Tuesday, Man was there a rat's nest under there. Also, a dead rat that was completely decomposed and I don't know how many pounds of rat droppings. Absolutely disgusting! I wore a face shield and dust mask the entire time I was working and cleaning. I uploaded a short video clip and a few pictures of the before and after. Also removed the transmission floor pan cover. There are several holes in the floorboard, but it is amazingly sturdy for something so rusted.
Haven't done a lot of work lately. Cut what was left of the bed retainer strips and boards out. After I get the bed off I'm going to get the engine out and on a stand. I was surprised at how small the transmission is in this thing. It's only about a foot long. Low technology = low space requirements.
I have to travel to Ecuador tomorrow for work. Shouldn't be there more than 7 days. Gonna jump into it a little more when I get home.
The body panels in my opinion are fine buying them after market but I would be very concerned about the frame rot. Body rust on the old trucks is nothing but the frame once they crystallize from sitting on dirt is a bad thing. I would not spend too much time on the driveling until I was clear the frame was ok!
