0 members (),
74
0
Mod | | | Forums66 Topics128,048 Posts1,055,540 Members48,425 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2007 Posts: 79 'Bolter | | 'Bolter Joined: Dec 2007 Posts: 79 | Looking to buy a 1949 chevy truck 1/2 ton. What year 235 eng. can I look for to install without a lot of problems would like to get away from the close driveshaft. Thanks | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | " . . What year 235 eng. can I look for to install without a lot of problems . . " Any 235 will install into a 1949 truck. 1. Use the 1949 clutch housing and clutch assembly. 2. If it is a 1955 or later 235 with the water pump body below the head, you will need to install a water pump relocation plate (from Pre '68 Dave).
" . . . can I look for to install without a lot of problems, would like to get away from the close driveshaft. . " You will incur more "problems" and $$ accomplishing this. | | | | | Joined: Feb 2001 Posts: 1,096 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 1,096 | Hi Tim , not sure what you would call "problems" . I have a '56 truck diff in my '40. with the original 4spd. Of course there was some cost involved getting a driveshaft made to fit and having the rear of the g/box to make a working seal , but it has been there for 20yrs and 80k miles , no problems
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | The choice of rear-end is independent of the choice of 235.
The install of any 235 in Ted's 1949 truck would pose fewer "problems" than would a drive-shaft/rear-end change. So, any year 235 would be OK.
I'd go for a 1954/55st 235 for the easiest installation. However, I think the 1956 or later 235s are better choices, but a little more work (waterpump relocation).
| | | | | Joined: Feb 2001 Posts: 1,096 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 1,096 | I see where you are coming from now Tim , I was focused on the closed driveshaft issue that the OP raised . | | |
