Firstly Green,welcome to the Stovebolt.
Here's a little guide I threw together for installing the back glass in AD trucks,the technique is exactly the same for corner glass on the 5 window cab.
If you click on the link it will take you to step by step pictures with descriptions.
I hope this helps.
Rear window install.
