1 members (texczech), 51 guests, and 2 robots.
Topics128,024
Posts1,055,395
Members48,422
#1178645 08/18/2016 2:38 AM
I have a 54 engine I am going to install into my 49 1/2 ton.The starter on the original engine uses a foot push start, the starter on the 54 has an electric start. Can I simply bolt up the original foot start starter on the 54 and it work or do I have to do other things?
Thanks!!!
billm #1178652 08/18/2016 3:39 AM
If the '54 engine has the original 6V flywheel (139 teeth) it will work. If the '54 was changed to a 12V flywheel when the solenoid starter was installed it will not work.
billm #1178655 08/18/2016 3:49 AM
H Online: Content
Check the stamped number on the machined pad behind the distributor. Chances are the engine was originally installed in a car, not a truck, and the solenoid-type starter was correct for the OEM installation. Also check the bellhousing the starter is bolted onto- - - -are the bottom holes where the transmission attaches threaded? If so, it's a car bellhousing.
