5 members (pauld, Uncles51, 60steve, Jon G, 1 invisible), 92 guests, and 3 robots.
Topics128,203
Posts1,057,286
Members48,467
I have a '52 1.5 ton stake with a 4 speed trans. I notice a clicking noise when I push in the clutch and coast slowly in second gear. Example: slow down to stop at the end of the driveway, push in on the clutch; it clicks about twice per second then will slow to nothing when I stop. Now, it is important to note that if I pop it out of gear while I'm rolling the noise stops completely,(clutch in or clutch out, no noise). Everything sounds fine when accelerating. I'm looking for ideas. I can't get my helper to hang underneath and listen; not that she would know what to listen to! It is not a violent noise and I'm not too concerned, but I would like to have an idea what might be causing it. Thanks in advance!
Let her drive it while you hang underneath. It's the gentlemanly thing to do. LOL. Does it only do it in first gear? Sounds like it is in the tranny.
so, how long has this been going on... at least I guess you have
eliminated the drive shaft...
Redryder pix
My Hotrod
Justhorsen ... yes, suspect it's in the tranny and it's just 2nd gear (I think)... Joker, I've put about 300 miles on it over the last year I have owned it and it's always made the noise. I don't think it's driveshaft, reason as follows: with the clutch in, the input end of the tranny stops rotating, but I still have noise (the driveshaft makes the tranny still turn). When out of gear, some portion of the trans stops turning and it stops the noise ... but the driveshaft is still rotating (with no noise). So it's probably in the trans and I guess until it "go boom" I will probably ignore it.
Big Bolt Forum Moderator
if you are coasting in gear, with the clutch pushed in, the input shaft of the tranny is still turning.
Mike
I stand to be correct, I thought you had it out of gear.. sorry
Redryder pix
My Hotrod
Sounds like a broken needle bearing in the U joint to me. When you unload the drive shaft it no longer binds the bearings.
You check the U joints you need to chock the truck, release the parking brake and put the trans in neutral. Then slide under the truck and see if there is any up and down or side to side play at the U joints.
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
If the noise stops when coasting in neutral, look for needle bearing problems at the cluster gear, and/or a bad ball bearing at the input shaft. I'd make a guess it's the cluster gear needle bearings. You could try dropping the cover plate off where a PTO would mount, and see if there's any end shake or up and down play in the cluster gear.
I had similar issues with my 1946 4 speed transmission. Worn counter shaft roller bearings that only made noise under load. This was a grinding noise, not clicking. They were quite when I pushed the clutch in and took off the load or coasted downhill. Nice in the sense that one gets a heads-up something is wrong before trany stops working all together.
