7 members (Gray_Ghost, Rusty Heaps, Brian Moore, 55shaker, Otto Skorzeny, Hotrod Lincoln, 1 invisible),
85
Mod | | | Forums66 Topics128,028 Posts1,055,414 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2013 Posts: 23 New Guy | | New Guy Joined: Mar 2013 Posts: 23 | All of the wiring for the horn on my 46 1.5 ton is basically gone can someone explain to me how to go about correctly wiring the horn in? My truck is almost completely finished!! | | | | | Joined: Dec 2015 Posts: 2,062 Big Bolt Forum Moderator | | Big Bolt Forum Moderator Joined: Dec 2015 Posts: 2,062 | generic horn wiring involves 3 parts and 3 wires.
1. Horn switch assembly (horn button and contacts in the steering column normally). 2. Horn relay 3. Horn
The 3 wires are as follows: 1. One wire going from the horn switch assy to the relay, this provides the ground to the relay (to activate it) 2. Hot wire to the relay (hot all the time) 3. Hot wire going from the relay to the horn, this is only hot when the relay is activated by pushing the horn button.
If - ground, Hot is +, if + ground, then hot is -. | | | | | Joined: Oct 2013 Posts: 331 Shop Shark | | Shop Shark Joined: Oct 2013 Posts: 331 |
1950 4100 - unrestored and driven weekly for almost no reason at all.
| | | | | Joined: Mar 2013 Posts: 23 New Guy | | New Guy Joined: Mar 2013 Posts: 23 | Where is the correct location for the Horn on a 46 1.5 ton? | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Where is the correct location for the Horn on a 46 1.5 ton? Left side of engine, on intake manifold. | | | | | Joined: Feb 2010 Posts: 476 'Bolter | | 'Bolter Joined: Feb 2010 Posts: 476 | I've got a 46 COE that I totally rewired,it has NO horn relay and the original horn works fine! | | | | | Joined: Aug 2010 Posts: 775 'Bolter | | 'Bolter Joined: Aug 2010 Posts: 775 | You don,t have to have a horn relay but it,s a good idea. All the relay does is reduce the current passing through the switch in the steering column. This should make the horn button last longer. It is a good idea to have a fuse in the circuit. Any circuit really.
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | A truck horn relay was not standard equipment until 1953. | | | | | Joined: Feb 2010 Posts: 476 'Bolter | | 'Bolter Joined: Feb 2010 Posts: 476 | Thanks guys, I've always wondered why mine didn't have one. | | | | | Joined: Mar 2013 Posts: 23 New Guy | | New Guy Joined: Mar 2013 Posts: 23 | I thought it was supposed to mount in the intake manifold, but my horn has a flange mount made of a piece of flat stock with a bolt spacing of about 4 inches. Looks to be original as it looks like the rivets holding the mount to the horn look original. Anymore ideas?? on the fire wall facing forward maybe?
I bought this truck as a project truck half finished so simple tasks like this seem to be difficult sometimes | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | jdchevy,
Mount it where ever you want/can.
Horns get changed over the years.
Also, car horns sometimes mount differently than truck horns (in the same year). | | |
