1 members (Hotrod Lincoln),
60
Mod | | | Forums66 Topics128,009 Posts1,055,293 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2012 Posts: 22 Shop Shark | | Shop Shark Joined: Jul 2012 Posts: 22 | Ok everyone. I am in the works of purchasing a GMC suburban. I have the serial number 101 22 P 54384. I need help pen pointing what year it is. It's a clamshell with sliding windows in the back, not solid like I've seen on some. Has 51 or newer doors because it has vent windows. If anyone can help it would be great!
Guillermo Ortiz Jr.
1950 Chevy 5 window with a 54 GMC cab swap
| | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | Seems to be a 1951 1/2 T "short" 116" WB, 228 motor, Pontiac, MI assy plant. Serial does not jibe. Are you sure it's "5"xxxx? Should be a "2"xxxx. Available with barn door or liftgate/tailgate. Do not see any with solid windows in rear. (Chevy info) You can do solid if you want that look. I believe the rear solid did not come in til the 60's. I did all solid on a 56 GMC Carryall.
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Jul 2012 Posts: 22 Shop Shark | | Shop Shark Joined: Jul 2012 Posts: 22 | It's a 1947-1954 Chevy, gmc , advanced design suburban! I've seen a 54 barn door here in Colorado with solid side window instead of the sliding ones. The GMC I'm looking at has the sliding side glass, with vent window on the doors. Along with the clamshell back lift gate. No seats but that's not a big issue. Owner I'm buying it from can't find the title. She doesn't know where her husband put it. And seeing they are hoarders she can't even begin to know where to look in that mess of a house of hers!
Guillermo Ortiz Jr.
| | | | | Joined: Jul 2012 Posts: 22 Shop Shark | | Shop Shark Joined: Jul 2012 Posts: 22 | And yes I'm sure it's a 5 xxxxxx number took a picture of it!
Guillermo Ortiz Jr.
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Guillermo,
Solid side windows were common on special equipment panel trucks (1/2 ton and 1 ton). All standard-equipment Suburbans came with sliding side windows (different slide handles and stops were used in different years).
1950 was the first year that a panel truck rear doors model Suburban was available, in addition to the tail-gate/lift-gate type "doors" Suburban.
1947-55 GMCs were called New Design trucks - Chevrolet trucks were called Advance-Design trucks.
Can you post a link to the picture of the ID tag?
Does it have painted bumpers and painted hub caps?
| | | | | Joined: Jul 2012 Posts: 22 Shop Shark | | Shop Shark Joined: Jul 2012 Posts: 22 | Tim Thanks that's great information on the suburbans, I have always thought the GMC's and Chevys were both advanced design that's good to know! I will try to upload a pictures of what I'm looking at. http://s1145.photobucket.com/user/gortiz315/media/Mobile%20Uploads/image.jpeg.html?sort=3&o=0I also put pictures of the suburban.
Guillermo Ortiz Jr.
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Guillermo, The code looks just like your description. 101 22 P 54384The 101 indicates 1/2 ton short bed The 22 indicates 228 engine The P indicates Pontiac engine plant 54384 = 1953 production year? Does it have painted bumpers and painted hub caps? | | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | A lost Title is the easiest thing to replace. Owner takes their ID and vehicle Serial Number to MVD to get a duplicate title. I've heard that lost excuse many times. Hopefully that's all it is, just lost.
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Jul 2012 Posts: 22 Shop Shark | | Shop Shark Joined: Jul 2012 Posts: 22 | It just has painted bumpers. No hubcaps are on it anymore.
Guillermo Ortiz Jr.
| | | | | Joined: Jul 2012 Posts: 22 Shop Shark | | Shop Shark Joined: Jul 2012 Posts: 22 | And yeah I'm hoping I can just take the old lady down there with me and I can get her to get one for me.
Guillermo Ortiz Jr.
| | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | Elderly lady....or just lady.
