1 members (Samantha), 45 guests, and 6 robots.
Topics128,021
Posts1,055,355
Members48,420
#1178134 08/14/2016 2:55 PM
My '49 1/2 ton Chevrolet truck originally came with a 3 position ignition switch off/run/start. The truck has the stomp starter. I've only been able to find 2 position switches off/run. My question is: I have converted the ignition to 12 volts with a Pertronix electronic ignition module. Will I need the 3 position switch so not to burn out the Pertronix ignition module? Have heard if you leave ignition switch in the on position for too long it will burn out the Pertronix ignition module. Does the ignition switch make a difference?
Tim
1970 VW Beetle
On a 56-?? truck (or, an earlier truck converted to 12v), if you leave a 12v 2-or-3 position switch on, both will provide a live and full 12v feed to the coil.
A 2-position switch was standard equipment on at least 47-55st Advance Design trucks (all were 6v). For this thread, let's ignore 6v solenoid starters on 54/55 Hydra-Matic trucks.
The later 3-position switch was designed to provide a full 12v feed to the coil when cranking; and, when not cranking, the switch is intended to run a 12v feed through a ballast resistor into the coil.
Pertronix provides wiring diagrams for their 12v units with a ballast resistor or with a coil with internal resistor.
Tim,
Thank you again for the fast reply! I have the Pertronix wiring diagram in hand. I using a 3 ohm internal Flame Thrower ignition coil and ignition module by Pertronix. So, what you are saying is that the using a 3 position switch versus a 2 position switch will not effect the ignition module if I follow the wiring diagram from Pertronix?
Tim
1970 VW Beetle
Tim,
Yes, but, be sure to turn off the switch if the engine stops and the ignition switch is still on.
Tim,
Thank you again!! Guess my 'ol man mind has started to go to mush? dang
Tim
1970 VW Beetle
Riding in the Passing Lane
I accidently left my key on over night as I was testing some things. It blew the coil wide open. Didn't hurt the Petronics though.
1972 Chevy c10 Cheyenne Super
The Chinese guy who built my aftermarket ignition switch caused both my coil and Pertonix module to fry. I shut the truck off and pulled out the key, and went to bed. Problem is, as I pulled out the key, the switch was moved ever so slightly toward the on position (should not be possible to do that), leaving the ignition on all night. It melted the plastic end of the coil and dumped the coil oil out and fried the Pertronix. Expensive day, that one was.
Carl
