0 members (), 160 guests, and 5 robots.
Topics128,149
Posts1,056,818
Members48,456
I own several '65 & '66 Chevy's that have the factory anodized aluminum grille & side trim and factory stainless steel "Custom" cab emblems on the rear cab pillar behind the doors. I have tried everything imaginable, including buffing (using various grits & types of compounds), polishing, Flitz, chrome cleaner, aluminum cleaner, etc, to remove the cloudiness and get them looking bright and polished, to no avail. Has anyone had any success restoring the lustre to these trim pieces? I would appreciate any tricks of the trade to get them shining again. Thanks for the input.
You have to remove the anodizing using a fine sandpaper or Easy-Off for a few mins, then you can polish it like normal. It will tarnish shortly w/o the anodizing tho, automotive clearcoat can be applied to protect. I saw a 66 at the car show that had all the moldings chromed w/nickel/chrome so I guess that's an option. Brian
My \'64\'s in the Gallery
Pictures in my Photobucket
1964 C10 Custom Cab 350/700R4
1964 Suburban 350/700R4
1979 Ford F350 4x4 400/c6
V
V Offline
The aluminum trim WAS NOT polished from the factory,it was bright dipped.
Gangster whites and straight pipes.....
