7 members (GMCJammer51, Phak1, Leo, Tom McGrath, dt235sd, DaveV, Paul_WNC),
106
Mod | | | Forums66 Topics128,050 Posts1,055,646 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2012 Posts: 126 'Bolter | | 'Bolter Joined: Nov 2012 Posts: 126 | The speed of my blinkers rises and falls with my engine rpm. The blinkers do not work at all when I turn my headlights on. All stock parts. I'm assuming I have a ground issue. Any ideas where best place to start? | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | Check the charging voltage & the battery. The voltage may be dropping to much at idle. If that's OK replace the flasher. You have 2 flashers on that truck. Be shure you get the right one. The other is for the 4 way. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Nov 2012 Posts: 126 'Bolter | | 'Bolter Joined: Nov 2012 Posts: 126 | | | | | | Joined: Feb 2004 Posts: 29,767 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,767 | Definitely a voltage problem, or possibly a dirty ground somewhere. A flasher relies on the proper amount of current flow to make the bimetal circuit breaker inside it heat and cool at the proper speed. You either don't have the proper voltage applied to the flasher, or one or more of the bulbs has a dirty ground, preventing them from drawing the proper current. Do any of the turn signal bulbs burn dimmer than the others? Jerry
| | | | | Joined: Nov 2012 Posts: 126 'Bolter | | 'Bolter Joined: Nov 2012 Posts: 126 | Jerry I'll check that and let you know. Thanks. Ps I've always been a bit of a dim bulb, but I don't think I'm the cause of this issue. A lot of other issues, yes. | | |
