| | | Forums66 Topics128,148 Posts1,056,809 Members48,454 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2008 Posts: 3,750 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 3,750 | Following a recent fender bender I've been considering upgrading and buying a set of the 'bolt in' Altman easy latches for my '50 as my originals are getting somewhat worn. Thankfully in the instance above the door(s) stayed shut,but i've considered the consequences had the doors actually popped.
I've read there has been some quality issues recently regarding some components that appear to have been outsourced. Apparently a small pot metal part fails causing the lock to jam,have any of you using these experienced any problems? I've been led to believe in order to actually open the door after the fact can result in damage to the door itself.
As many of you know i'm on the opposite side of the pond so I have to consider shipping and duties etc so they aren't that cheap either,even more so as the $/£ rate kinda sucks right now! Any warranty/replacement situations that might arise are compounded by this and add to the fact my truck is a daily driver so being off the road for any reason is also very inconvenient to me,especially as replacements could take some time.
Any comments/input are welcome, 1950 Chevy Advance Design 3100 in ScotlandIn the Stovebolt GalleryMore pix on Flickr. I've definately got this truck thing in my blood ... my DNA sequence has torque settings"Of all the small nations of this earth,perhaps only the ancient Greeks surpass the Scots in their contribution to mankind" Winston Churchill.
| | | | | Joined: Mar 2010 Posts: 10,298 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,298 | Are your hinge pins good and tight? Sloppy hinge pins lead to sagging doors which beats the latch mechanism to pieces. I have completely disassembled mine, cleaned them up and TIG welded new metal where excessive wear has removed metal. I used the passenger latch as a guide as to how much metal was missing (passenger latches don't get used as much as the driver's side, so the wear isn't too bad). Carl
| | | | | Joined: Mar 2010 Posts: 10,298 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,298 | I have considered offering a service for repairing original latches for folks in need, but I am afraid that the cost would be prohibitive. Carl
| | | | | Joined: Mar 2008 Posts: 3,750 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 3,750 | Yeah Carl,the hinge pins are good,I rebuilt the drivers side last year and yes the passenger side had seen very little use,the P.O. must've been a loner.
I've already had to replace the latches once already and was liking the idea of true bear claw ones for that extra security.
I've heard good things about the Altmans but hopefully they'll address this quality issue soon before I fall out my door!
| | | | | Joined: Sep 2013 Posts: 93 Shop Shark | | Shop Shark Joined: Sep 2013 Posts: 93 | I had nothing but trouble installing. There was mis-alignment between the latch and the square rod extending from the door handle. Followed their directions to a T. Ended up modifying their latch to work on my truck. No answers why..... Also, there is no lock ability with the set I bought. On a good note they work well after I spent two days modifying for proper operation. STAY STOCK STAY HAPPPY! And 300 clams richer. My two cents--
1947 GMC Truck 5 window, Long Bed 2008 Corvette Roadster 2008 Harley Davidson FXDL 2011 F150 Ecoboost 4X4 2015 Subaru Outback AWD "only the strong survive"
| | | | | Joined: Dec 2006 Posts: 206 Shop Shark | | Shop Shark Joined: Dec 2006 Posts: 206 | It does take some experience to do these. The first one we did was nothing but trouble. Second one was easier but the handles drooped until we swapped some parts around. third one was easy an worked out OK. But no locking with out a modification in the door that's not easily done you have to use electric locks.
