2 members (50Chevy3100, 41 chev), 143 guests, and 2 robots.
Topics128,265
Posts1,058,365
Members48,485
#1177542 08/10/2016 2:15 PM
The Novak rebuilt SM420 is in and working great! Bolted right up to the bell housing on our 235 1957 engine. The only real change was to move the exhaust pipe over a bit and a new driveline with a new slip yoke was needed. The driveline was done by Driveline shop in Sacramento. The old driveline for the BW R-10 was too short. The shifter cane is located perfectly with plenty of room and is at the correct height. At 2500 rpm we are a bit over 55 mph that's plenty for a truck with drum brakes. Stomp starter fit right in no modifications. The area once occupied by the old tranny is clean without all the monkey motion rods that the PO had attached to a floor converter shifter. So it's been a good choice for me and maybe somebody else out there. Thanks to Bill and Bartamos for their X-tra help! Steve
WHO, ME ? #1177851 08/12/2016 3:52 PM
What size gears are you running in back? 411?
Craig
WHO, ME ? #1177934 08/13/2016 5:11 AM
Wish I knew...at 2500 rpm 55mph....never touched the rear end but it did come out of a 56/57 vehicle along with the 235 and the Borg Warner R-10 transmission. It has 10 bolts on the cover if that helps? If you find out let me know.😄
WHO, ME ? #1177941 08/13/2016 9:37 AM
My 56 turned about 2600 rpm at 55 mph with the stock 3.90 gears. +/- 100 rpm can easily be explained by differences in tire size. The cover also has 10 bolts. So 3.90:1 is my guess smile
i have the 3.38 set in now and my rpms have dropped 300-400 @ 55 mph
WHO, ME ? #1178105 08/14/2016 4:11 AM
Thanks...I been wanting to get a set of Patrick's gears that should drop my rpms I don't know by how much but I'll give Patrick's a shout out. Seems like a lot of work so I'll stick with more life in the slow lane for now. Besides with a chrome 54 grill....you don't get home with bodacious chrome....everybody wants to tell you that they had a truck just like that and they wish they kept it making you late for home because of chrome!
WHO, ME ? #1178463 08/16/2016 9:56 PM
I have Patrick's 3:55 gears in back and run 2200rpm at 55mph. This is with a dialed in speedometer that reflects 215/85R16 tires.
Craig
WHO, ME ? #1178481 08/16/2016 11:40 PM
3:38:1...,is what I would like to install with my 15" tires. I was told they came on hydramatics....I'm talking to a shop right now about a change of ring and pinion. I'll post what I find out.
