5 members (TooMany2count, Otto Skorzeny, MickeyP, Wally / Montana, Bill Hanlon), 101 guests, and 2 robots.
Topics128,052
Posts1,055,729
#117773 09/28/2005 9:12 PM
This post should probably go in the tool chest, but would get more visibility here.
for you rural folks, the TSC chain, (Tractor Supply Co.) has a pre Christmas tool package of a Mig Welder, floor cart, gas regualtor, face shield,gloves etc... for $299.00. Even less if you have a 10% off coupon!!
All you need is your argon/CO2 bottle. It is made by Campbell Hausfeld but under the TSC/Farmhand name and powereful enough for light body work, (sheet metal and angle up to 3/16" thick. Works pretty good actually
not a bad price if you cost it out individually.
Great price on new cylinders on E bay too for under a hundred bucks then your ready to go!!
Mike
1951 Chevy 1/2 ton w/ 1959 235
1971 Chevelle
#117774 09/28/2005 11:06 PM
Does it have a live tip or is it switched? Many of the cheaper welders do not switch off the voltage to the gun when the trigger is released, so be careful to check. I like a dead gun when I put it down.
I wouldn't expect much of a face shield with that price, even my $499 Lincoln came with a crappy sheild.
Paint & Body Shop moderator
#117775 09/29/2005 2:33 PM
Anonymous
Unregistered
Anonymous
Unregistered
If all you are doing is sheetmetal work that rig might be fine. I would suggest instead the Lincoln HD3200 package which is available at HomeDepot for about $400. Better quality than C-H. Hard to argue with the price though.
Just for your information, TSC in this area also rents gas cylinders for welding and cutting rigs. They are in a cage outside the store.
