6 members (Shade Baby, TexasA&M48Truck, tclederman, Hotrod Lincoln, Bill Hanlon, 1 invisible), 82 guests, and 2 robots.
Topics128,094
Posts1,056,483
Members48,444
#1177575 08/10/2016 5:42 PM
Stovebolt Photo Moderator
Good afternoon Bolters, I am searching for a part number for my 3800 king pins. I come up with MOOG 8294B however the keeper bolt across the spindles through the flat of the pin looks different in the picture here:
http://www.aftermarketsuspensionparts.com/moog-8294b
Any comments? Do these look OK? Thanks - Joe
1947 - 3800 dually known as "Deadwrench"
Link to a few photos
In this world there are givers and takers. The takers eat well, the givers sleep well.
Joey,
sent you a pm
~ Jim Schmidt, Bucks County, PA
1953 Chevrolet 3804 1-ton
In the DITY Gallery
The picture looks appropriate, if the part number traces back to your application I'd say they're right.
In general when shopping for kingpins I search for ones with the bronze bushings instead of plastic and thrust bearings instead of washers.
Usually more than one possible kit or part number exist for each application.
•1952 Chevrolet 3800 pickup
---All pictures---
Rockauto- ACDELCO 45F0013 is what I used on my 49 3800. I had to take them to the machine shop to have the bushing honed to fit.
( http://www.rockauto.com/en/catalog/chevrolet,1947,truck,3.5l+217cid+l6,1486576,steering,king+pin+set,7340?a=Referer+www.google.com+URL+%2Fen%2Fcatalog%2Fchevrolet )
1949-52 Chevy 3800 1-Ton Flatbed
More pix on Photobucket
I also used the Rockauto parts and had to have my bushings honed to fit.
Reaming or honing the bushings to fit the pin is part of the process. If you didn't need to ream them that would be cause for concern.
---All pictures---
The goods have been ordered. I'll keep you all posted on the installation. Grigg - if the replacement bushing is snug in the spindle, and sized for the companion pin is honing still required ? - Joe
The bushing will be undersized for the pin.
They are installed in the spindle and reamed or honed inline with each other and to fit the pin. Standard practice for kingpins.
---All pictures---
Joe,
I had mine pressed in by a heavy duty truck service center. This way they took care of everything that was needed for a correct fit.
In the DITY Gallery
---All pictures---
Checked the last post and am confused says half ton does not need to be reamed . I did not have to ream mine.54 half ton .is a 3800 a bigger truck
1954 Canadian GMC 9300
"The Journey"
Follow in the DITY
A 1/2 ton is a 3100
A 1 ton is a 3800
Were not talking about 1/2 tons here in the Tons o' Fun. They are different and have unique king pin/floating bushing situation not found on most any other vehicles with king pins.
3/4 ton and up are pressed in bushings and reamed to fit, common practice.
---All pictures---
Moderated by  Dusty53
