3 members (rfs56trk, Shade Baby, Otto Skorzeny), 69 guests, and 0 robots.
Topics128,038
Posts1,055,585
#1177566 08/10/2016 4:49 PM
Hello
I have just finished an 8 year project restoring a 46 1/2 ton with the original 216 engine.
The engine has good compression in each cylinder about 105 lbs and good oil pressure stays at about 10 lbs after driving for a while at an idle and valves have been gaped to proper tolerances. I am very excited to have it on the road and driving around the back roads. My question is about the valve noise as it seems to clatter away most of the time which I think is normal and not excessively loud. Then once in a while the clatter disappears and you can't here anything, is this normal or should I be looking into something. Looking forward to hearing from some other more seasoned bolter's about whats going on Thank you
Check the undersides of the rocker arms where they contact the valve stems. Quite often, they will get cupped to the point a feeler gauge doesn't give an accurate adjustment, and until the engine gets fully warmed up and the valve stems and pushrods "grow" a little the clearance is just a little too wide, causing a rattle. Some oldtime machinists (myself included) have an accessory for a valve grinding machine that resurfaces the valve stem contact area of rocker arms and eliminates the adjustment error.
Thank you Hotrod Lincoln for the information is it something to be concerned about or something I could put off for a winter project?
I'm sure a large majority of stovebolts have at least a little of this sort of wear/noise issues. Some folks think they're supposed to sound like that. It won't hurt to run it until it's convenient to do a little investigating. BTW, being slightly noisy is much better than being "quiet and too tight" which could lead to burned valves and/or a miss from low manifold vacuum.
46chevinline6 #1177621 08/10/2016 11:02 PM
V
V Offline
I 2nd Jerry. My 216 clicked and clacked away for about 2 yrs after I got it running and I too thought it was normal. The engine ran fine and judging by the worn rocker arm tips I'd say it ran like that for quite awhile before it was parked for an extended sleep.
I finally decided to pull the valve train and dress up those rocker arm tips and the difference is night and day. A 216 can actually be pretty quiet for a solid lifter engine that is grin
