5 members (Gray_Ghost, Gdads51, Wayne67vert, 6inarow, klhansen), 86 guests, and 0 robots.
Topics128,052
Posts1,055,740
#117730 09/20/2005 9:53 PM
Can i paint my wheels with the same sys. [base coat, clear coat] as the rest of the truck? I would sand blast them first then use a eching primer. Any help would be app. Paul
PJP
#117731 09/20/2005 11:19 PM
yes, that's normal procedure
#117732 09/21/2005 4:24 AM
alot of people also have them powder coated.
robert
Robert French MY3800FIRETRUCK
#117733 09/21/2005 8:20 PM
Francis if you look a couple of post down the list you will see a post "Billy Bob update...." check it out there is some good info there if you are going to do it yourself.
Brian Moore
1949 3100 5 window Deluxe
"Today is better than yesterday, but not as good as tomorrow"
#117734 09/22/2005 3:36 PM
If you have a Les Schwab in your part of the country, they only charged me $20.00 per wheel to sandblast and powder coat them. Cheaper than good paint and a lot easier.
#117735 09/24/2005 12:38 AM
Painted and cleared them, they look Great!
PJP
#117736 09/27/2005 12:10 AM
If you have an old oven available (don't use it for food when you are done) bake the wheels at very low temperature (like 150) for 12 hours and that will accelerate the drying process of the clear coat. You want it good and hard on the wheels before you put them in service.
Paint & Body Shop moderator
#117737 09/27/2005 2:42 AM
Remember to take the tires off before baking them. grin
#117738 09/27/2005 11:46 PM
You will want to bake them before installing the tires, so they stand up to the tire machine better.
#117739 10/04/2005 1:31 AM
What about the durability of the powder coat to the tire installing machine?
#117740 10/04/2005 8:11 AM
Most new wheels are powder coated. Just have the tire guys put the tires on from the back, they will be fine.
#117741 10/04/2005 7:24 PM
Tab Offline
I just shoot them with enamel. I wouldn't bother with a two part paint system on the wheels.
delete my account and pictures
#117742 10/05/2005 1:06 AM
V
V Offline
Question: Are the wheels the same color as the body in 1951? If not, what color should they be painted?
