OK Guy,s I realize that that I can put the arms such as on a 1/2 ton model but are they correct?Will they look right on a one ton? What i,ve got on the old cab has those angle iron brackets and tubular mirror arms,paint shot, brackets loose,cowl sheetmetal damaged.gonna fix all that. On the new cab I have the same setup,but only longer arms as it came from a 6400 series, same year fertilizer truck that had no frame leftunder it and gratiously gave up alot of needed parts. any replies/suggestions gratefully appreciated.
