0 members (),
84
Mod | | | Forums66 Topics128,062 Posts1,055,857 Members48,428 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2002 Posts: 59 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2002 Posts: 59 | Now that I have my bed-sides back and ready, what is the best way to attach the new corner strips? Can I drill through both and use nuts and bolts or is it best to weld? Any other possibilities? Thanks | | | | | | Anonymous Unregistered | | Anonymous Unregistered | I just replaced my angle strips on the 54 bedsides. I drilled out the original spot welds, removed the old strip, c-clamped the new strip in place and spot welded through the holes to the new strip. I would not bolt them in place as then you have the heads and nuts showing and you never want to go out in public with those showing. | | |
