1 members (52Carl),
63
Mod | | | Forums66 Topics128,079 Posts1,056,309 Members48,442 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2013 Posts: 178 Shop Shark | | Shop Shark Joined: Dec 2013 Posts: 178 | My 49' 3100 AD is just about ready for its first lap of the neighborhood. It was a basket case with no gen or alt. I found 12 volt bulbs everywhere, and it fired right up and ran on a 12 volt battery. The voltage reg was disconnected. So........I'm assuming here that it had an alternator. Is the Delco 7127 one wire 10SI 63 amp the right choice? Any feedback would be great. Thx.
Have you ever noticed that anyone driving slower than you is an idiot and anyone driving faster than you is a maniac? - George Carlin
| | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | If you have enough accessories that you need a 63 amp alternator I'd recommend you get one with the sensing wire still functional. If you don't have a lot of accessories you don't need that many amps and a one wire should be sufficient.
That is my opinion and you'll find many on this subject. | | | | | Joined: Dec 2013 Posts: 178 Shop Shark | | Shop Shark Joined: Dec 2013 Posts: 178 | Thanks cletis, I wont be running a thumping stereo, flat screen or blur ray. Just a basic 2 speaker radio, upgrading to led lights and need a place to plug in a phone and gps. If there are additional things to do while I'm at this please feel free to jump in here anyone.
| | | | | Joined: Dec 2015 Posts: 2,063 Big Bolt Forum Moderator | | Big Bolt Forum Moderator Joined: Dec 2015 Posts: 2,063 | from what you stated, a one wire should be fine. That is all I ran on my 59 Suburban, and that had 4 headlights instead of 2, no LED lights, and I had halogen driving lights and a thumping stereo in it (also towed a trailer with lots of lights from time to time), I never had an issue with not enough alternator.
| | | | | Joined: Dec 2013 Posts: 178 Shop Shark | | Shop Shark Joined: Dec 2013 Posts: 178 | Thx Mike- I might do a small trailer once and awhile, so thanks for reminding me to find a trailer hitch plug.
| | | | | Joined: Dec 2015 Posts: 2,063 Big Bolt Forum Moderator | | Big Bolt Forum Moderator Joined: Dec 2015 Posts: 2,063 | I just put a 7-way on my 58. I get all my 12v wiring stuff from http://delcity.net/ They have good prices on wiring, ends, trailer plugs, etc. | | | | | Joined: Dec 2013 Posts: 178 Shop Shark | | Shop Shark Joined: Dec 2013 Posts: 178 | 69cuda, Very cool site with great prices. Thx. Marko
| | | | | Joined: Jun 2012 Posts: 1,747 'Bolter | | 'Bolter Joined: Jun 2012 Posts: 1,747 | 63 Amps might be too much for the Amp meter? If you plan to run the truck mostly stock, then 35 Amps should be all you need. It will run the lights, even a trailer, and a radio, and still charge the battery. It is the same rating as the Generator so no issue with the Amp meter. Someone here will know if 63 Amps is too much for the meter. You could put a shunt across it, but that tends to mess with the function. Any one here know if the meter will be OK at 63 Amps?
Steve H
| | | | | Joined: Sep 2011 Posts: 305 Shop Shark | | Shop Shark Joined: Sep 2011 Posts: 305 | I put a 105 amp, single wire in my '54 and it worked great. Easy to wire and install. | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | I can guarantee you a 105 amp is not "the right alternator" for most of our old trucks. | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | 54John3100,
Did you run the output through the 1954 amp gauge?
