9 members (artinva, Gdads51, 1955 1 Series, tesa, JW51, Peggy M, VicZ, Ridgeback, 1 invisible), 93 guests, and 0 robots.
Topics128,077
Posts1,055,932
Members48,430
#117683 09/15/2005 2:38 AM
I was wondering if there is a way to rib reproduction runing boards to make them look like the original
thanks,
JJ
JJ
#117684 09/15/2005 2:57 AM
I think the original ribs are stamped.. as heavy as the metal is, it must have been a hell of a stamp/press thing (and probably expensive) which is likely why the repros are smooth.
I don't know how you'd put the ribs on an aftermarket running board.. but if you figure out how to do it cheap, you could make quite a few bucks buying the repros, putting the ribs on, and reselling them!
#117685 09/15/2005 10:24 PM
thanks for the help
JJ
#117686 09/16/2005 8:30 PM
You should be able to approximate it with a bead roller, but you would have to be able to get it around the flange, which might be difficult. The other way would be to get the ribbed patch panels and weld them in.
Paint & Body Shop moderator
