| | | Forums66 Topics128,078 Posts1,056,027 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2010 Posts: 117 Shop Shark | | Shop Shark Joined: Jun 2010 Posts: 117 | Hey all,
Well I just replaced the two expansion plugs on the intake/exhaust side of the block with new brass ones and they both leaked on me. I put them in dry and seated them about a sixteenth into the casting.
I pulled them out today and am going to try it again. This time i'm going to really clean the machined surface well with emery (probably 600 grit) and but some sealant on them.
I'm thinking of using Permatex Aviation Sealant but am open to a different type that others on the board have used with success.
If you go the sealant route, is there a prefered type for this application?
I really don't want to do this again!
1955 Chevy Cameo 235 engine 3 speed transmission
| | | | | Joined: Feb 2000 Posts: 5,213 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,213 | Really clean the block, rotary wire brush works well, it should be shinny, clean metal.
I like to use Permatex® Aviation Form-A-Gasket® No. 3 Sealant Liquid , This stuff never really drys and seals really good.
Joe | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Mar 2010 Posts: 10,279 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,279 | Permatex #2, or Indian Head sealant works well too.
| | | | | Joined: Jun 2010 Posts: 117 Shop Shark | | Shop Shark Joined: Jun 2010 Posts: 117 | Thanks everybody, I'm gonna go with some sealant this time for sure.
Also, I purchased a installer kit instead of using a socket to drive them home. I used a 1 1/8 socket for the 1 5/8 plugs. It fit just inside the lip, and read many posts where people had no issue with this.
I did find a few articles that stated these plugs are better tapped in using the tool that applies the force on the rim of the cup, instead of the inner edges around the rim like the large socket does.
I'll be taking the carb, intake, and headers off the engine again tomorrow and take a good look at the holes to make sure they are as clean as I can get them before I drive the new ones home.
| | | | | Joined: Jun 2010 Posts: 117 Shop Shark | | Shop Shark Joined: Jun 2010 Posts: 117 | Well just an update, I reinstalled the freeze plugs with some Permatex Aviation sealant.
They both weeped a bit but much less. After a couple of heat cycles the rear plug near the throttle pivot sealed itself.
The front plug is still weeping ever so slightly. I am gonna let it head cycle a few more times and if it doesn't seal itself will probably try some Bar's Leaks radiator stop leak tablets. It says 2 tablets per galloon so I was planning on putting in 8.
Their website says the are harmless to your system and can seal minor leaks. They also say many OEM companies sell them and also put them in new car coolant systems at the factory.
Anybody had bad good or bad luck with these tablets?
| | | | | Joined: Jun 2010 Posts: 117 Shop Shark | | Shop Shark Joined: Jun 2010 Posts: 117 | Just ran her again, and looks like that front freeze plug sealed up, i'm keeping my fingers crossed but no seepage or leaks this time.
