| | | Forums66 Topics128,126 Posts1,056,354 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2014 Posts: 125 Shop Shark | | Shop Shark Joined: Feb 2014 Posts: 125 | I have just received my CCP master cylinder and booster. The booster has a 3/8" OD inlet but all the vac. outlets on my 1975 / 250 in line 6 are all 3/16" OD. Should I drill a hole in the intake manifold and tap it for a 3/8" fitting or ? Anyone done this before? Hope I have the required 18 lbs of vac they suggest. | | | | | Joined: Dec 2014 Posts: 678 'Bolter | | 'Bolter Joined: Dec 2014 Posts: 678 | Your nearest auto parts store carries many adapters, T's, Y's, etc. It should be easy to locate a 3/16-to-3/8 brass or plastic adapter. Don't drill/tap your manifold; besides being irreversible, it's a lot of work and it's also likely to get metal filings into your motor.
1951 Chevy Panel Truck
| | | | | Joined: Jan 2016 Posts: 631 'Bolter | | 'Bolter Joined: Jan 2016 Posts: 631 | A 3/16" line might have real trouble supplying adequate vacuum volume. | | | | | Joined: Feb 2000 Posts: 5,221 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,221 | You should have a 3/8" port on the center intake runner, between the carburetor and the valve cover. This is where the PCV valve hooks up. You are not really suppose to tie into the PCV line with the brake hose, but it may be your only option other then drill and tapping. You could make up a thick carb spacer with a 3/8 port drill in it, it would be pretty easy to make and install.
Joe | | | | | Joined: Feb 2014 Posts: 125 Shop Shark | | Shop Shark Joined: Feb 2014 Posts: 125 | Joe H. What would I make a carb spacer out of. Are they made of an insulating material or would aluminum be ok with a gasket on each side ? | | | | | Joined: Dec 2015 Posts: 2,063 Big Bolt Forum Moderator | | Big Bolt Forum Moderator Joined: Dec 2015 Posts: 2,063 | if your carb is getting too warm and boiling gas out after you shut it off, you would want to make a spacer out of an insulating material. If everything works fine and you are just wanting put it in there to add a vacuum port, aluminum is fine. | | |
