| | | Forums66 Topics128,034 Posts1,055,536 Members48,425 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2012 Posts: 142 'Bolter | | 'Bolter Joined: Jun 2012 Posts: 142 | What holds the shaft in that comes out of the master cyl.It is the part that has the grease zerk . in it There is a flat spot on it,but the M/S where it goes in is smooth. This is on a stock 56 ,3200. | | | | | Joined: Dec 2015 Posts: 2,062 Big Bolt Forum Moderator | | Big Bolt Forum Moderator Joined: Dec 2015 Posts: 2,062 | are you talking the pedal pivot shaft? There is a bolt and a U-shaped washer that fits into a groove in that shaft (at least on my 58 and 59, I am assuming 56 is the same). Once that bolt is out, nothing is holding the shaft in place. | | |
