5 members (55shaker, 49nut, ndkid275, Gdads51, Rusty Rod), 112 guests, and 3 robots.
Topics128,130
Posts1,056,367
Members48,441
Good morning,
I recently purchased a '45 Chevy pick up that's 97% complete. The previous owner tells me it started life as a military truck. There are some minor trim pieces and finishing touches needed. One of those items is the door stops, that prevent the doors from opening too wide.
I've search the archives for information and found a few threads for mid-to-late '30s and '46 and up trucks. I am hoping someone can help understand if the door stops on a '45 are the same or different than the models of the '30s or the '46+ AD trucks.
Pictures of the door jams showing the stops and possible sources for locating these parts would be appreciated greatly.
I am also looking for a hard copy of a '45 service manual. Most of the stuff I've found on-line are pre-'41 or post-'45 references and a couple US military books that generally cover all vehicles from '41 thru '45 but not really specific to my truck. Has anyone come across a suitable service or maintenance manual for a '45?
Thank you in advance for all your help.
Cheers,
Carlos - Madison, WI
Door check or stop, http://www.oldchevytrucks.com/cart/product.asp?prodid=DP137&i=|door%20check||||
I doubt you find a manual on the '45, that was war time. '41 -'46 are the same truck so look for before or after the war time for manuals.
