8 members (cmayna, baldeagle, Bill Hanlon, Leo, Hotrod Lincoln, Mike in Sycamore, Gdads51, 1955 1 Series),
120
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,113 Posts1,056,280 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2000 Posts: 1,438 'Bolter | | 'Bolter Joined: Aug 2000 Posts: 1,438 | Anyone have a picture they could share of the rear bumper brackets for '40 burb or panel? This bumper type dishes forward in the center. I have a few parts that may be correct but don't know for sure or how they assemble to frame and bumper.
Dennis
40 Chevy 1/2 ton
| | | | | Joined: Aug 2000 Posts: 1,438 'Bolter | | 'Bolter Joined: Aug 2000 Posts: 1,438 | I've looked at the gallery, but didn't see anything showing the rear bumper brackets. Sure could use some help with this one.
Dennis
40 Chevy 1/2 ton
| | | | | Joined: May 2016 Posts: 6 New Guy | | New Guy Joined: May 2016 Posts: 6 | bowtie bits antique trk parts carries them,they have a picture | | | | | Joined: Aug 2000 Posts: 1,438 'Bolter | | 'Bolter Joined: Aug 2000 Posts: 1,438 | Thanks Forty Burb. I only saw the brackets for the 1/2 ton. Are you saying the 1/2 ton is the same as the burb?
Dennis
40 Chevy 1/2 ton
| | | | | Joined: May 2016 Posts: 6 New Guy | | New Guy Joined: May 2016 Posts: 6 | the burb could be 1/2 ton or 3/4 ton,mine is 1/2 ton ,my rear bumper was modified .I am looking for my brackets,somewhere in my storage,my wheelbase is 113.5 inches and has a KC designation,I will send you pictures when I find them .good luck | | | | | Joined: Aug 2000 Posts: 1,438 'Bolter | | 'Bolter Joined: Aug 2000 Posts: 1,438 | That would be a big help Forty Burb. Looking forward to seeing what you have.
Dennis
40 Chevy 1/2 ton
| | | | | Joined: Jun 2005 Posts: 96 'Bolter | | 'Bolter Joined: Jun 2005 Posts: 96 | The rear bumper brackets for burbs/panels with lift gate (clam shell) are the same as for the 1/2 T Pick-up. If it has the doors, the brackets are different, so as to accomodate the recess in the bumper for access to cargo area. I have a 46 which I believe has the same rear bumper. Unfortunately it is in my home town 1500 miles away. The body is being prepped to paint, I will call and check on getting a photo of the bracket.
best of luck on your project, Richard
Richard J Patrick - 1946 Suburban
| | | | | Joined: Aug 2000 Posts: 1,438 'Bolter | | 'Bolter Joined: Aug 2000 Posts: 1,438 | That would be helpful too Richard. From what you describe, I would be looking for the brackets for a burb/panel with doors to accommodate the recess in the bumper.
Dennis
40 Chevy 1/2 ton
