1 members (Hotrod Lincoln),
130
Mod | | | Forums66 Topics128,143 Posts1,056,494 Members48,442 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2002 Posts: 2,168 A teacher, but always an apprentice. | | A teacher, but always an apprentice. Joined: Apr 2002 Posts: 2,168 | Wrapping up final metal touches on my one ton. After I completed my running boards and steel I had to come back to fix an issue. My home made running boards turned out awesome except for one hiccup. I have a slight wave in both. I have been reading about oil can effect, but this wave seems excessively tight. Push down hard and it pops very loudly and moves noticeably. I'm not sure if this is in fact an oil can or if the panel itself has actually warped. I have been replanishing welds to little effect. However, I tried a small torch and quench but it scares me and seemed to make it worse. Also I'm not sure as to how to read an oil can and where heat should be applied. On the other hand, where would planishing be beneficial to drop this wave? Thanks 😖 | | | | | Joined: Jul 2011 Posts: 785 'Bolter | | 'Bolter Joined: Jul 2011 Posts: 785 | If you are having trouble reading the oil can, think how someone on the other side of the keyboard feels. In order to get more accurate suggestion for repairs, take a video that shows any welded area(s), shows you cycling the oil can in both directions, shows the surrounding area, and post the YouTube link. Then post a still photo so that someone can add circles and arrows, to better describe a repair..  | | | | | Joined: May 2012 Posts: 574 'Bolter | | 'Bolter Joined: May 2012 Posts: 574 | you will need to heat and quench with a torch. not nearly as hard as it seems.
1949 Dodge Coronet 1955 2nd Chevy 4400 1.5 ton 1955 2nd Chevy 3100 1/2 ton 1955 2nd Chevy 3100 1/2 ton 1957 Chevy 5400 LCF 2 ton 1966 Dodge D100 Sweptline 1968 Chevy P20 stepvan 1969 GMC LWB pickup 1972 GMC Sprint 1974 CP30 shorty bus There are three things that I've learned never discuss with people: religion, politics, and the Great Pumpkin.----Linus Van Pelt Trying to understand the behavior of some people is like trying to smell the color 9 | | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | However, I tried a small torch and quench but it scares me and seemed to make it worse. Also I'm not sure as to how to read an oil can and where heat should be applied. On the other hand, where would planishing be beneficial to drop this wave? Thanks 😖 This is the exact problem. Where to apply heat and how much. No one can tell you exactly, even an expert. So if you "guess" wrong, you are cooked. You will have start over. So think, wait for other responses and then decide. Someone may give you mini-step by mini-step instructions on how to shrink/expand.
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Apr 2002 Posts: 2,168 A teacher, but always an apprentice. | | A teacher, but always an apprentice. Joined: Apr 2002 Posts: 2,168 | I built the boards in pieces, front and back with 16 gauge. The undersides have 3 braces, but theses are also the mounting points. As I welded, I allowed for cooling and planished slowly as I went. It took a ridiculous amount of time to weld them out because of this. I plan on applying bed liner so it should hide some of the imperfections but I irritates me when people sit on them and pop! May call it good enough and move on. Thanks for the positive feedback on how they turned out. | | | | | Joined: Jul 2011 Posts: 785 'Bolter | | 'Bolter Joined: Jul 2011 Posts: 785 | Some pictorials to help explain what is occurring, may be a good lesson for someone else trying this in the future.... Any time we weld, especially with a MIG, you have a shrink that occurs circumferentially about the weld dot, pulling from ALL directions. Despite efforts to allow cooling in between, the majority of the shrink and distortion in using the MIG is the starting and stopping. If one were able to tack the pieces in place and then perform a non-stop weld from one end to the other (using TIG or Gas) you would see much less distortion as the panel heats up gradually as the weld puddle progresses across the panel, and cools down gradually in the same fashion. With a MIG, even welding one dot at a time, it is a quick in and out, for the possibility of more distortion from shrinking. Planishing with either method is a must to counter the effects of shrinking, but a continuous pass will help to limit the weld distortion. Looking at the running board: http://i5.photobucket.com/albums/y167/rmccartney/Metalworking/RunningBoard.jpgThe upward bent flange near the body helps to keep things from moving. Ideally, if a flange were bent on the outside in a similar fashion, it would have eliminated much of the distortion you realized, depending on the heat introduced when welding on the brackets beneath. Given that welds were used in attaching the outside flange, with each weld dot we realize a shrink at each spot, and the distortion that comes with it. As the weld cools it is pulling the metal in from all directions, even though the picture only shows two directions. The shrink/pull in the direction of the red arrows may tend to draw downward, losing some of the sharp 90 where there may be more of a slight radius at the corner. Anything pulling in the direction of the blue arrows is going to shrink the length along the edge. So when you combine an area that doesn't want to move (yellow line) and an area that is moving (blue arrows), that transition area in the middle starts to form a sinusoidal wave as the shrink causes what outwardly appears as extra metal.. One of the best samples of this, lay a piece of paper in front of you landscape. Left index finger on lower left corner, right index finger on lower right corner, and push your fingers toward each other, representing weld shrinkage. Note the buckle in the lower edge of the paper. This is what is happening to your running boards. As with any oil can, the "fix" is determined by the cause. Here we have shrinking that occurred from welding, so the CORRECT manner of fixing this type of oil can is to stretch the weld and HAZ. Not an easy task given the location. But likely the easiest way to do so, given the 90* bend, is to use a section of press brake die with a sharp 90, clamp in a bench vise and hammer toward the top of the die, parallel with the 90* planes, where we would expect the weld and HAZ area to be. I would note that welds, especially if MIG was used, will be notably HARD. You would be wise to insure the press brake die is hardened or make it so using Casenite or other hardening process. http://i5.photobucket.com/albums/y167/rmccartney/Metalworking/Planishing1.jpghttp://i5.photobucket.com/albums/y167/rmccartney/Metalworking/Planishing2.jpgNow although this is the correct method of repair, given the difficulty of weld location and other factors, the REALISTIC method of repair, after exhausting planishing efforts, will be to shrink the bulges. Heating with a torch, I would heat to a size of about a dime, and cool. Start in the center of each "bulge" and work your way out circumferentially. FOOD FOR THOUGHT. You've done some nice fabrication work on your truck, love the dually. But welding and flat sheet tend to cause issues like you have here. To help combat this in a fabrication process, bending both the inner and outer flanges would eliminate heat introduced distortion. Adding ribs using a Pullmax or other similar reciprocating machine will make the panel more resistant to distortion with the introduction of heat. A bead roller may work, but it shouldn't have HF or Princess Auto on the box if you're going to tackle 16 ga steel. Hope my ramblings help out.. | | | | | Joined: Apr 2002 Posts: 2,168 A teacher, but always an apprentice. | | A teacher, but always an apprentice. Joined: Apr 2002 Posts: 2,168 | Thanks Robert. I wanted to bend the board all in one piece but the weird angles and differing widths prevented me from doing so. This was the way I could do it with the tools I had available at the time, I appreciate the advice and help guys. I will give these options a go.
| | | | | Joined: Jul 2013 Posts: 863 Shop Shark | | Shop Shark Joined: Jul 2013 Posts: 863 | Heat them from the center out in small increments and use a metal shrinking hammer and dolly working from the inside out until you get the metal flat and back into shape. I've done this with many heavy metal surfaces and had good success.
Tim
1949 Chevrolet 3100 Series 1/2 ton Pickup 1964 Chevrolet C10 (Ol' Yella) (SOLD) 1958 Chevrolet Biscayne 2 door (SOLD) 1970 VW Beetle
| | | | | Joined: Feb 2011 Posts: 583 'Bolter | | 'Bolter Joined: Feb 2011 Posts: 583 | The running boards on my 39 also have 3 braces. 2 for the mounting brackets, and 1 running down the middle, from front to back.
Rick
1939 Chevrolet Stake Truck
| | | | | Joined: Jul 2011 Posts: 785 'Bolter | | 'Bolter Joined: Jul 2011 Posts: 785 | We recently added a bead detail surrounding some louvers on hood sides. Where this isn't normally the type of beads you see on running boards, it added quite a bit of rigidity & strength where something like this should correct the warp issue. You'd have to remove the braces underneath long enough to bead them, but a series of these added parallel would add quite a bit of strength. http://www.garagejournal.com/forum/showpost.php?p=5865987&postcount=1982 | | | | | Joined: May 2015 Posts: 11,078 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,078 | Robert, you are the master of field expediency (also known by a non-PC term).  That "fancy vice jigsaw" is just one example. Also the "patented vice grip iPhone" holder. One would have to be very careful about the adjustment of the pliers on that one. They don't give those phones away. It'd be a shame to crunch one. Awesome work on the beading. I'll be building one of your "donut dollies", and possibly a custom set of dies when I start working on my running boards (that just need a little tune-up on the beading.)
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Apr 2002 Posts: 2,168 A teacher, but always an apprentice. | | A teacher, but always an apprentice. Joined: Apr 2002 Posts: 2,168 | Update: I removed the board and I "planished the snot" out of the running board along the leading edge. It took a long time, but I have successfully dropped the highs and lows considerably. I also rebuilt the mount point to the frame bracket as a couple degree variation in height contributed to the severe dip previously built into the board. It isn't perfect, but I'm very happy that progress was made. Now, onto the other side  Robert, that bead tool is pretty handy! I really like the look of those louvers lined by the bead. Maybe I should start saving pennies for one myself. That would be a welcome addition to my ever shrinking workshop.
