| | | Forums66 Topics128,037 Posts1,055,468 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2008 Posts: 117 'Bolter | | 'Bolter Joined: Nov 2008 Posts: 117 | Hello I have a Canadian made 1946 1/2 ton. Just wondering if someone can tell when and where the truck was made from the serial # or the engine # or if there is any place you can get this information ser# 6131407627 eng # C140890 Thank You | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | you won't find much info on Canadian production .... would have been assembled in Oshawa, only plant in Canada by that time .... some numbers here, likely the truck was assembled from "left over" parts of 42-45 Bill | | | | | Joined: Nov 2008 Posts: 117 'Bolter | | 'Bolter Joined: Nov 2008 Posts: 117 | Thx Bill that gives me some information | | |
