3 members (sron48, Otto Skorzeny, 1 invisible), 89 guests, and 1 robot.
Topics128,154
Posts1,056,856
Members48,456
Does the yoke go to trans case or towards axle? Does it matter? Forgot to make mental note when removed.
~ HB
1962 Chevrolet C10
1962 Suburban
Big Bolt Forum Moderator
you mean the slip yoke end? as long as it does not have the double u-joint on one end, the slip yoke goes on the transfer case end. That way it is up out of the way and less likely to get scraped on a rock and swamped with mud.
Mike
Sir Searchalot
Sir Searchalot
As you know, there are 3 "propeller shafts". All have slip yokes. The slip end, according to 1960 GMC manual (same T221 and system), is as follows: Front diff shaft: Slip at TCase. Transmission shaft: Slip at transmission. Rear shaft: Slip at TCase.
Be sure to note that there could be factory stamped arrows on male and female slip assy. Should be aligned and pointing to each other. This is what GMC shows. Chevy= not sure. I have them on my 1960 GMC 4X4.
Did not see any marks. Thanks for info. Apparently, I made the right guess. Thought the slip yoke might be at transfer case to keep it out of danger. And confirmed the other drive shafts are also as described above. Thanks again.
Hambone
~ HB
1962 Chevrolet C10
1962 Suburban
Sir Searchalot
Sir Searchalot
I did not see the arrows either until I was cleaning for painting. They are, I guess, to ensure "phasing". BE SURE they are phased. Your slip yoke assy could be keyed with a fat spline. So can't be installed incorrectly, Not sure.
